Another case of wrapped 57's...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, May 26, 2004.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Another case of wrapped 57\'s...
    Just figured that I'd drop a quick post to let folks know that I thrashed a set of Ford 57's on the first time out this past weekend at the Badlands Offroad park in Indiana. Got so bad at one point that I used a set of vise grips to clamp the pack together to help it not wrap. PICS of what they look like after the trip:
    Now the question is - when I go hunting for a new set of springs at the yard, what is my best choice? My current thought is 3/4 ton 56" leafs from a late 80's Burban. Sound about right? I've already got the Echobit flip and 6" shackles as well.
    Ideas?
    Thanks!
    -Dan
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Re: Another case of wrapped 57\'s...
    That sucks. I have been wheelin' my 57's HARD for over a year now and have had no problems at all.
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I don't know if its the tire size, the doubler, or what it is... but they bent up real quick. Ah well... hopefully I'll have better luck with the 56's. /forums/images/graemlins/weld.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Dan, you can also find the 56's under some 3/4-ton pickups. I just grabbed a set last week to replace the sagging 1/2-ton 56's under my '90 Suburban. /forums/images/graemlins/cool.gif
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    What year did you pull yours from? I looked over a few the last time I went to the yard, and all I could find in PU's were either 52" or 63" packs... /forums/images/graemlins/blush.gif
    -Dan
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    DAHMN! Glad I've got 56's sitting in the garage waiting to go in. What I done was removed the top leaf of the old 52" pack and used the top two leaves of the 56" pack... WHALA 1/2ton 56" pack /forums/images/graemlins/grin.gif
    old top leaf and new top leaves pic #2 closeup of front and rear eyes, also of trimmed leaf
    You could turn the top 2 leaves around to either get a stock offset or 3" offset. Since I'm using the echobit flip and I already have a longer driveshaft for a taller lift I flipped the leaves to where its going to place the axle back 3.5" (then minus an 1" for the flip /forums/images/graemlins/thinking.gif) I could redrill the pack or use a zerorate if I needed a little more lift. another offset pic
    As soon as I put a couple bucks in my pocket I'm going to find some cheap 6" shackles and ubolts and put my lift on. So it could be a couple months before I get to test them out. /forums/images/graemlins/tongue.gif /forums/images/graemlins/smirk.gif
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I think I'm just going to run the 3/4 ton spring for awhile... we'll see how it effects my flex. I really just want to be able to hammer on the gas and not worry about tearing the rear axle out.
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I think there is about the same # of leaves in both packs maybe a couple more in the 56"pack and leaves are a little thicker.
    There are some 56" 1/2ton burbs also...
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    But most of them have sagged to the point of being about useless. /forums/images/graemlins/frown.gif That's why I'm stepping up to the 3/4-ton springs on my '90 Sub.
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Does flipping the spring leafs around really move the axle back how ever many inches /forums/images/graemlins/confused.gif
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    only if your using the 56" top leaf in place of the 52" like I did. Click on the links above for pics.
    The 56" and 52" springs are the same length from the front eye to the center pin... that makes the 56" spring 4" longer in the back. If you use them like I did, then yes it can move your axle back. I believe the 52" springs the center pic is centered, the 56" springs the center pin is not. Both are 26" from the front spring eye.
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    OOOOH /forums/images/graemlins/peace.gif I get it now...So I replace the top 52" leaf with the top 56" spring to move it backwards? Interesting /forums/images/graemlins/woot.gif
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Or you can use the 56" spring complete.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    But there are significant geometry issues when you flip the springs. I'm running flipped 57s. I've been through 4 sets in 2 years... Going coils (hopefully) before the latest set dies on me... /forums/images/graemlins/frown.gif Anti-wrap will help the longevity quite a bit.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Ideas?
    Thanks!
    -Dan
    [/ QUOTE ] Is that what they call built Ford tuff ??? /forums/images/graemlins/whistling.gif
  16. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    /forums/images/graemlins/histerical.gif
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, I supose they could do like the 52" GMs and just sit there, stiff as a board, until they eventually break... /forums/images/graemlins/smirk.gif "Like a Rock!" /forums/images/graemlins/histerical.gif
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  19. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    My 52's aren't broken...
    I don't SEE any reason why 57" springs would benefit...
    there isn't many DRY ROCKS around here...
    When I went wheeling with Dan...
    I saw nice rear flex...but at the same time...
    I saw axle-rap out the ass!!!
    Since traction isn't as good out here...
    busting a set of 57" springs is more likely...
    from tire-spin...then braking a set of 52"s...
    from too much flex...just ask Dan!!!
    Just my .02!!! /forums/images/graemlins/wink.gif
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sure, but with big tires and gear reduction/power, leaf springs are rather challenged to control wrap anyway (even 52s, but they will typically do better than longer) especially if you have blocks. Add an anti-wrap bar and you have fixed that problem for any spring so you can get the rate/flex you want without sacrificing for axle wrap control (which leafs are notoriously bad for). And as for breaking 52s, I've been seeing broken 52s for most of my life. I saw them back in AL with the muddy hill climbs and trails and I've seen quite a few more of them out here in the rocks. My son's K5 which had never been wheeled hard at all had both 52" rears broken when we got it.
