another cross over question
Discussion in 'The Garage' started by purple76pearl, Jun 3, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    ok so i finally got the axles i want, and now have a spare dana 44 with the steering knucles i need, im getting them machiend at www.wagnormachine.com, i think thats the site, but anyway, i need the drag link, and tie rod ends, and steering arms and stuff, i have the sector shaft out of a two wheel box, but kinda lost on everything else, help please i beg of the
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dont understand....... what do you need help on?
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
  4. purple76pearl
    Jan 13, 2003
    450
    missouri
    well what i dont understand is where to get teh following parts, and which ones i need
    cross over pitman arm for the steering box once i put the 2 wheel drive sector shaft in
    passenger steering arm
    and new drag link coming from steering arm to passenger knuckle
    i know they are different then stock but dont know which ones i need to make this all work correctly
    having teh knucles machined is no prob i have that one under controll
    the rest, i know what it takes and how to set it up
    just dont know the specifics on what i need, does that make sense /forums/images/graemlins/k5.gif
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i used a 78-79 ford 4 inch drop pitman arm, superlift part number 1104, $50 at 4wheel parts, sky mfg should have the steering arm you need, and for the draglink i had a friend cut a section out of my old ten bolt tierod, then he put in a piece of solid steel in the middle and welded it back together, this was so i could still use the threads on the end of the sleeve... You could just find a offroad shop who makes draglink sleeves... Or you could go to ORD and have them make your draglink, they can make a bent draglink so you wont have to change your engine crossmember.
  6. purple76pearl
    Jan 13, 2003
    450
    missouri
