Another crossover/highsteer Q
Discussion in 'OffRoad Design' started by Ronnie4wd, Jun 15, 2005.
  1. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    I have a M1008 with 6" lift and need to put on highsteer.
    Things I already have or going to fab:
    2wd box with pitman arm
    Tierod with ends
    Draglink with ends
    Things I need to buy:
    RH steering arm
    LH steering arm
    Studkit.
    Did I get something wrong?
    Is the pitman arm from the 2wd good for this or do I need a new :confused:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You will need a superlift part #1104 pitman arm.
    The 2wd one will not work.
  3. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    Thanks for the fast reply.
    When I order things from ORD I will get the pitman arm from them.
    Everything else right?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You'll need stud kitS, otherwise, you have it right. It should be everything you need. You might consider a kingpin spring and bushing kit since you're going to have the arms off already, it's an easy time to change them out.
  5. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    If I can get any parts here in Sweden such as tierod ends and other GM parts I will,
    because I think the big cost will be the shipping.
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i second the bushings and spring kit for the 60. i have changed a few in my time and when arm or cap is off change them if you havent before. good luck.:cool1:
