Another dana 60 question
Discussion in 'The Garage' started by highlow, Dec 27, 2004.
  1. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    I have a stock axled 74 blazer with 36" swampers on it, and slowly finishing the rest of the truck so I can finally take the damn thing hunting with me. Just yesterday a neighbor I didn't now came up to my house asking about a water tank I had laying in the back of our property that he was interested in. While we're talkin he notices my blazer and mentiones he has a set of 8 lug 3/4 ton axles. He keeps yapping about how bad he needs that tank so basically I told him I would trade the tank for the axles maybe but that I needed to go look at the axles first.
    So my question is what are identifying marks on the axles that I can look for to figure out exactly what they are. Also to sweeten the pot he claims that there is a transfer case and a transmission that go along with the axles. (supposedly these were purchased by a buddy of his that was going to convert a 2wheel blazer to a 4 wheel a long time a ago and never did it)
    EAT BEEF
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    There is a tech article here with about 20 different diff cover examples, you might print this and take it with you.
    A front D60 is identifyable by 4 bolts holding on the steering arm, a D44 or 10 bolt will have 3 (with the arm being horseshoe shaped). Take a look at the arm on your K5 for a 3 bolt example. A D60 will also have 1 ubolt and 2 studs for the pass side spring (beware a Dodge D44 uses a similar set up).
    You might also post up some pics if you have a digi camera. :thumb:
  3. highlow
    Oct 8, 2002
    124
    can you give me a little more on where to find the tech sheet you are talking about. Yeah I do agree with the camera idea I was actually planning on that just for more input from you guys.
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Here is the Axle ID Chart - http://coloradok5.com/axleguide.shtml :thumb:
    (You can find it with the drop down menu at the top right of the page. Go to "Technical", this article is at the very bottom).
  5. highlow
    Oct 8, 2002
    124
    thanks
  6. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    well if he sed 3/4 ton axles its not a 60, unless he dosnt know what hes talking about
  7. highlow
    Oct 8, 2002
    124
    according to the tech sheet the 60 was used in 3/4 ton pickups and vans, so he could be right.
  8. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    The dana 60 was only used in a 1 ton chevy truck. Dodge however does use the d60 in 3/4 ton trucks with the cummins diesel. And ford did use them with the f250 snow package.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    The tech article mention the 60 could come in the 3/4 ton "REAR ENDS".. Not in the front. Only the 1 tons had the D60 front. Unless it was something like a Quiggly conversion on a Van....
    What he probably has is a 14FF rear with a D44 or 10B front. But it could also be a 14SF 8 lug rear.
