ANOTHER "do you like this engine setup" thread by me. . .
Discussion in 'The Garage' started by BowtieRed, Jan 21, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ANOTHER \"do you like this engine setup\" thread by me. . .
    ARP-134-3701 Chevrolet: 262-400, cast iron OEM or Brodix -8, -10, -11, -11xb heads, 12-point, head bolt kit $58.95 $58.95
    ARP-134-5202 Chevrolet: 262-400, 4-bolt main, large journal, main bolt kit $25.88 $25.88
    ARP-134-6003 Chevrolet: 305, 307, 350, 409, high performance, connecting rod bolts $39.88 $39.88
    CCA-12-210-2 Chevrolet: 262-400, 268/268 degrees duration, hydraulic, High Energy, camshaft $93.95 $93.95
    CCA-K12-210-2 Chevrolet: 262-400 268/268 degrees duration, hydraulic, High Energy camshaft K-kit $309.95 $309.95
    CLE-CB663P Chevrolet: 305, 307, 327, 350, 400 rod bearings $2.50 $2.50
    CLE-MS909P Small Chevy: 305-350 main bearings $20.95 $20.95
    CRN-11621-16 Chevrolet: 262-400, stock length, 5/16 in. diameter, 7.765 in. long, pushrod set $95.88 $95.88
    EDL-1812 800 cfm, manual choke, Edelbrock Thunder Series AVS carburetor $369.95 $369.95
    EDL-2101 Chevrolet: 262-400, dual plane, cast aluminum, Performer, intake manifold $114.95 $114.95
    FPP-1004 Chevrolet: 262-400, .041 in. compressed thickness, 4.190 in. gasket bore, 9.2 cc compressed volume, head gasket $32.88 $32.88
    SME-3-48-05-100 Chevrolet: 350, 5.7 in. Stage I connecting rods $219.95 $219.95
    SUM-G6920B Chevrolet: 262-400, 1.6 ratio, 3/8 in. stud, aluminum, anodized blue finish, roller rocker arm set $189.99 $189.99
    UEM-1436030-8 Chevrolet: 350, .030 overbore, 3.48 in. stroke, 5.70 in. connecting rod, flat top, hypereutectic, piston set $59.69 $59.69
    this is using a stock block, .030 over, with stock crank, and stock heads, which maybe or may not be ported. this motor will NOT be going in a truck. will be in a light street/strip car.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: ANOTHER \"do you like this engine setup\" thread by me. . .
    that seems like a WHOLE LOTTA carb for .03 over 350 with stock heads and crank..
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i would think which head castings will be important..
    what kinda car?
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    [evil chuckle] 1st gen RX7
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    whoops! i meant to clcik 600 . . . . either way, Desktop dyno has me pushin 400 on hp and torque with this setup.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think you need to try a dual pattern cam.
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I agree, a dual pattern cam will give you more power. I was gonna ?? the 800 CFM, but i see that corrected. And if your gonna run longer ratio rockers, would you please..please.. remember to check the pushrod slot in the heads if you using stock heads! I can't tell you HOW many times i have said that!! The pushrod will hit/scuff/bend! AND HAVE IT REBALANCED! But anyways, the rest looks good. Do you have a head plan? what car is it going in?
  8. dyeager535
    26,980
    I agree, if you want performance, look at ditching any stock head other than the Vortecs or L98's. Some old camel hump 2.02's are ok, but they still suck in the combustion chamber, and the castings aren't as clean nor as refined.
    Not saying Vortecs or L98's are all that, but when you say stock head, can't think of anything else you'd likely have that would be even close.
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Those Stage I connecting rods already come with ARP bolts.
    Summit's description:
    "This set of Summit Stage I rods is recommended for street engines with up to 9:1 compression using pistons with press-fit wrist pins. We magnaflux every rod, then bore size the big-end for roundness and proper bearing/oil clearance. The rods also feature chamfered bolt holes for use with ARP rod bolts (installed). You won't find a better rod anywhere for the price."
    I would also look for a dual pattern cam, or better yet...ask Comp Cams what they recommend.
    Heads are where its at, so if you can get a good aftermarket set, with today's technology, it will make a huge difference in performance.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok, well that'll save me money. this is going in a first gen RX7. totally gutted. . .raceweight under 2k hopefully /forums/images/graemlins/laugh.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In that case you need to build a 302 or 327 and wind it to the moon. With that low of weight, a torquey build like that is a waste of time.
    I say build a 327 with forged everything, 12:1 or so compression, maybe a little lower. Aluminium heads, and a HUGE solid roller cam. Redline it at 9,000 or so. Might need NASCAR parts to keep it together, but it'd be a rocket!
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    dude. . . this is not my life project. . . something out of the junkard, rip out the rear diff, put in a leaf sprung/ladder barred truck ten bolt and this relatively cheap engine with a M20/21/22 or a TH350.
    i repeat. . . NOT something i want to dump 10g into.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got a stock forged crank 327 block and crank in my garage, come and get it and it's yours.
  14. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    forged block? i'd take up up on that if i have enough gas to drive 500miles each way. . .
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No. A stock forged small journal 327 crank and the original virgin unbored block to go with it. /forums/images/graemlins/thumb.gif
  16. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    LOL Id do it but gas is already 1.50 for 87 here and i spend all my money on gas just going to my GF's house. So unless you can ship it to me somehow for free like tie it to the back of a semi truck heading my way.....
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Amazing that two people want it here and I can't give the damn thing away to anyone but the scrap man around here...not to much want for a small journal motor.
  18. dyeager535
    26,980
    Post it up on a corvette forum. Those guys are crazy/serious enough to maybe want one. /forums/images/graemlins/smile.gif
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not small journal stuff.
  20. dyeager535
    26,980
    They are if they want a motor that is semi-correct for their year vette.
