Another driveshaft question... 1979 Suburban 6" lift
Discussion in 'The Garage' started by SuburbanGuy, Jun 17, 2005.
  1. SuburbanGuy
    SuburbanGuy Newbie
    Jun 16, 2005
    4
    Manor, Tx
    I apologize if this seems redundant, but I did a search and could not find the same situation mentioned.
    I have a 1979 Chevrolet Suburban with a 4" lift with rear blocks. I'm going to a 6" lift with rear springs. My driveshafts are fine with the 4" lift and my u-joints are good.
    Does anyone out there have the 6" setup on their older Suburban? Any problems with driveshafts being too short or angles too steep? U-joints? It is a Rough Country kit, and I don't know if the kit has an angled shim on the rear spring pack or not, or if it would be necessary to shim at all.
    Thanks for your time, and I apologize for the Noob question.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    With your long wheelbase you should be ok driveshaft wise.
    As for that kit, I hope you are not looking for a sift ride. I have there front springs and they ride like a tractor. Just a word of warning. :)
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    same w.b. as long bed truck. i had 6" in my old one. with 1 tons and 4" flip in back and 2 " block to level out rear. was fine no problems. frt was a tad grindy at times with flex. but i had no sway bar also more flex. rear was fixed yoke transfer. slip shaft might be close.
  4. SuburbanGuy
    SuburbanGuy Newbie
    Jun 16, 2005
    4
    Manor, Tx
    Thanks for the input, guys. I appreciate your responses.
    I'm hoping my 35's will absorb some of the shock!
  5. SuburbanGuy
    SuburbanGuy Newbie
    Jun 16, 2005
    4
    Manor, Tx
    On the same note, the vent tubes for the front and rear diffs are very taut. Have you guys ever had to lengthen them?
    Anyone know what OD/ID tubing that is and where to find it and the connector to lengthen them?
  6. sweetk30
    Nov 1, 2004
    25,526
    526
    just regular fuel /vent line hose. easy fix.
  7. SuburbanGuy
    SuburbanGuy Newbie
    Jun 16, 2005
    4
    Manor, Tx
    Thanks again for the help sir.
  8. sweetk30
    Nov 1, 2004
    25,526
    526
    tell ya what dont thank me thank ck5 site. easy to fo become a paid member and look at all the stuff and all the cool pics. but be warned it is vary adictive. good luck on the build up.
