another driveshaft/ujoint newb question.
Discussion in 'The Garage' started by colbystephens, Jan 8, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok - so i'm trying to change out my ubolt so i can run the 14bff i have under my rig. after you pull the c-clips, what do you do?
    edit - i'm an idiot and meant to say ujoints. i need to swap in the conversion joint and can't figure out how to remove the old one.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I dont know about anyone else but you lost me when you ask about C-clips and changing to 14 blt. If you are swapping axles there is no need to remove the c-clips, just unbolt the 4 ubolts disconnect brakes and e-brake and disconnnet d-shaft. Put new axle under install new ubolts, connect brake line and ebrake, bleed brakes, and install conversion ujoint and reconnect dshaft.
    What are you really asking, put it simple I have had a quite a few New Castles:D.
    Ira
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Up is down and down is up:confused:
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok. so apparently i need to figure out what the hell i'm talking about. :) sorry. basically - how do you change a ujoint. sorry, just realized i previously said ubolt and meant ujoint.
  5. sandawgk5
    Oct 28, 2003
    6,881
    If it is the stock shaft the caps are held into the yoke on the shaft with injected plastic rather than a snap ring or clip. You have to melt that out and then press the caps out with a socket larger than the cap on one side and one smaller than the cap on the other.
    Ira
