another dumb question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nstarry, Mar 16, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    will a TBI intake system work on a carb (little modification) /forums/images/graemlins/dunno.gif
    if so that looks like a good start to a snorkel
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can use a whole tbi system on a carb motor. Some newer ones have dofferent center intake bolts, take that into consideration. Some companies like Edelbrock and Holley offer tbi sytems that bolt onto carb intakes. If you mean you want to use just the air cleaner assembly on an existing carb,I don't have an answer, I never done that. /forums/images/graemlins/thumb.gif
  3. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    sorry I didnt word this right I mean the air cleaner assembly
    they make the side draft setup with the long tube that reaches over to the side with the tuner air cleaner on it
    I was just thinking that would be a good start to a snorkel /forums/images/graemlins/k5.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am sure if you are used to working on Chev's you can make do. Post a pic when you do. /forums/images/graemlins/thumb.gif
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    A TBI air cleaner will work no problem, it has the same size hole(5 1/8), you may or may not need the spacer to allow thw air cleaner to clear the choke
  6. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    Thank you I wasent going to spend 70 bucks to find out
