Another electrical problem... UGH I HATE ELECTRICAL PROBLEMS
Discussion in 'Pacific Region' started by Topdown, Jul 3, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... I go away to Detroit for a trip, the blazer sits for 4 weeks... I get in, fire up drive into town, no brake lights.
    I have turn signals, emergency flashers, tail lamps, etc... but no brake lights. I replaced the brake light switch (at the pedal) still no lights. I have checked and there is power at the switch and it appears to be working appropriately but still no brake lights. No juice at the back end of the truck, I cant even tell that there is juice at the firewall... I HATE electrical issues.
    Thoughts anyone?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Check every since ground you can find in the brake circuit. Sounds like you just have a bad ground to me.
  3. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    Whenever I lost brake lights on any of my Blazers it always seemed to be the wire had rubbed itself through where its routed through the frame near the rear bumper. Check your connections at plug ins and anywhere it maybe routed through frame or anything that might wear it thin. Also check power at random back to the tail lights.
    If you need any help just yell I think I could pry Jeff away from his busy schedule to help /forums/images/graemlins/histerical.gif
  4. mudslinger97116
    mudslinger97116 1/2 ton status
    Mar 13, 2003
    315
    F.G.OREGON
    i feel for you topdown,i have been fighting the same problem in my blazer theres a post in the first gen. forum that might give you some more ideas.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    the same thing just happened to my MINI that thing has so many eletrical gremlins its not funny /forums/images/graemlins/dunno.gif
  6. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    check all the way under the frame to the bumper...Mine did that too, but with just the tail lights and one of the wires got severed some how.
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Theres a connection behind the rear bumper more to the drivers side in the body under the tailgate. Its a 4 pin I think if its plugged in un plug it and look at the pins. Make sure they aren't corroded from sitting. clean them off and see what happens. You can also use that as a testing point.
  8. JDBlazer454
    Feb 27, 2002
    951
    Vancouver, Wa
    I saw you yesterday cruisin it so I take it its fixed?
  9. Topdown
    Nov 26, 2002
    2,598
    nope, not fixed, but i needed to get to lowes to get the parts to fix the CAI on the Vue... /forums/images/graemlins/whistling.gif
  10. JDBlazer454
    Feb 27, 2002
    951
    Vancouver, Wa
    /forums/images/graemlins/grin.gif I have done that /forums/images/graemlins/whistling.gif Get the attitude hey go ahead and try to hit me you will be the one hurtin /forums/images/graemlins/histerical.gif
