another electrical??
Discussion in 'The Garage' started by boggerless, Mar 19, 2005.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    all the gauges worked except the oil pressure, so i pulled out the cluster only to find out the oil gauge is electric. i want the line running to it . anyway now that the cluster is back in the only gauge that works is the volt meter, and the gas gauge somewhat. if i put on the headlights the oil presure gauge drops?? but nothing else changes. WTF???? thanks daryl
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    might be a ground problem, there is a gronding bloc on the left hand side behind the dash on the wall make sure is is conected to it othere than that.... ill shut up:crazy:
  3. boggerless
    May 26, 2003
    22,728
    96
    thanks,i'll check it. i hate this crap i'm about to buy seperate gauges and mount them on the dash.:laugh:
