another exhaust post
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Oct 16, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    ok
    as it stands, glasspacks then side exit pipes behind the tires...
    im wanting to go back to turbo's for noise and performance(they were better at both)
    im thinking of just nixing tail pipes altogether...
    any advantages of having turn downs on the outlets of the mufflers as opposed to tailpipes?
  2. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    What about that exhaust when youre parked? Is your rig AIRTIGHT? /forums/images/graemlins/laugh.gif Do you ever wheel through grass? You wouldnt wanna leave it running while parked for any length of time.
  3. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I run NO exhaust after the cat. No fumes killin' me, YET.
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, just aim the turndown basically towards the bottom of your rear tire and you'll be fine. I havent seen it in a wind tunnel, but what I do know is that Im not chokin on exhaust gases in my rig when I drive with the top on or off.
    the theoretical negatives seem pretty irrelevant... i mean, the hottest part of your exhaust is going to be your cat, not whats blowing out past the muffler... if you are parked in tall dry dead grass (and wth are you doing off the trail anyway?!) then your cat will be much more likely to start a fire. parked/running for a really long time? wha? when does that happen? maybe if you're in ur garage and trying to commit suicide or something! /forums/images/graemlins/rotfl.gif
    j
  5. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    LMAO! /forums/images/graemlins/laugh.gif Good times!
  6. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Mine just end at the muffler (near the rear axle, left side). I planned on running turndowns right on the muffler but haven't got around to it. I only get fumes when the rear window is down, and even then its only a faint (no pun intended) smell.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    mine has turn downs right before the rear end, no negetive effects so far. I don't notice exhaust in the truck when driving, unless the back window is down, but thats a common problem.
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    In VA the exhaust must exit out of the passenger compartment. In your case if you lived here, (dont know WV rules) the exhaust would have to exit either out the back, or the sides. To pass inspection you would have to add tailpipes.
    On a pickup its different. You only have to go behind the cab, then you can do turndowns...
    Just my .02..
    John
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    be careful if you are stuck in mud with the engine running last weekend we had a guy with this setup almost lose his daughter to carbon monoxide poisening she stopped breathing CPR and gettting her out of the truck saved her so always be aware of the danger.
