Another F150 spring ?
Discussion in 'The Garage' started by wayne, Jul 3, 2002.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Does anybody know the spring eye size compared to a GM? If they are different where do you get greasable bushings for them?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Well, I already installed my early 90's packs but my early 80's packs are sitting here and look to be the same...
    1 1/4" front
    1 5/8" rear
    Hopefully, someone else can
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Ok, reason I ask is, I have a set of 56" GM springs here but everybody said the F150's are much better so before I rebuild the 56" ones I will get a set of 57". Also wondering if it would be a good idea to go with a lowering shackel and laying it back some for even more droop with the flip.
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The shackle angle idea sounds good, I did the same, but you might want to find a way to install one of the 57's first and see exacly where it sits with your weight on it. Then you'd know just how much of a shackle length your going to want/need and can purchase of fabricate accordingly. Make sure the lowering shackle is sturdy enough too! I'm really happy to see so many people moving to the ford springs, blazers are just too stiff from the factory and this is a relatively inexpensive way to get competetive!
