another front zero rate/x-over ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Dec 9, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Still thinking about moving the front axle up a little - are you guys moving it 1" or 1.5" ?
    Also, I searched about x-over interference with the right leaf spring and the idea was to check to see if you have clearance now. I don't have crossover yet, so I can't measure. What have you guys seen?
    In a search, I found this:
    Here is an excellent tip I learned from thebigdaddyof2 (Todd). Take a stock steering arm and cut it off just even with the knuckle. Use this as your spacer, it has the holes already drilled. Weld this to your new steering arm to raise it 1".
    Sounds like a good idea. Would it HAVE to be welded? I don't see how that wold help anything. I have a welder and could do it, just don't see why.
    -- Mike
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Here is an old pic of mine. I made a set of 3/4" zero rates for the front and in the pic the drag link was actually sitting on the spring. I have the zero rates set to move the axle forward 1" when I put them in but my driveshaft was to short so I just used the center hole. Also my steering arm is only 3/4" thick so a 1" thick one would have gave me a 1/4" more clearance.
