Another GEAR question - telling the difference in gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jjlaughner, Oct 22, 2002.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK, I have looked through the last months worth of GEAR posts in the search and have not come up with what I'm wanting to find out. HOW, do you tell one gear from another? Ring size, # of teeth, #of bolts, is it stamped somehwere, chevy vs. other brands. I see a few posts that says 'let me take of the cover and see what gears are in it.' How can you tell, how can I tell if I pull the covers off my junkyard finds. D44, 14bolt, and a 12bolt. Same rules apply for all or are they different for each axle? Multipart question I guess. mainly interested in 14bolt and D44 for my new project, but I'm thinking of swapping out my 12bolt if it matches up with my current 10bolt front in my daily driver. Thanks, Jeremiah /forums/images/graemlins/confused.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I think you are asking how to tell what gear ration the axle has.
    The most reliable way I've found is to count the teeth on the ring gear (say, 41) and count the teeth on the pinion gear (say, 10) and divide the former by the latter.
    41 / 10 = 4.10
    Use a piece of chalk to mark the tooth you start and it makes it easier.
    -- Mike
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you turn the ring gear you will find stampings on it's edge. These numbers include the ratio. Some put 41/10 and then 4.10:1 and some just put the numbers 41/10.
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Sounds pretty easy so far, time to head to the garage and get dirty! J
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Part one is axle ID...after a while you can ID almost any domestic diff from 30 feet/forums/images/graemlins/smile.gif It just takes a while to get familiar with them all.
    http://coloradok5.com/axleguide.shtml
    As was already posted the ratio is stamped on the edge of the ring gear. You can count the teeth if you want though... /forums/images/graemlins/grin.gif
    Rene
