Another good deal or not post...picked them up today, thanks folks
Discussion in 'The Garage' started by angrysnowplow, Jul 17, 2003.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Alrighty, got a few choices:
    1. Dana 60(locked) + 14FF(locked) - 4.56 gears and "30,000 miles on them" $1,400
    2. same deal as above, rear locker only. $1,200
    3. Dana 44 + 14 FF - 4.56 gears, open $800
    Hauled #2 home a little while ago...pic at the bottom if anyone cares. /forums/images/graemlins/thumb.gif
  2. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    Re: Another good deal or not post...1 ton stuff
    give me the number and i'll umm call em... /forums/images/graemlins/cool.gif
  3. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    To confirm the ratio you can count the teeth or most of the time there stamped on them. If by "locked" you mean detroits, I would go with number one since a detroit for a front 60 is in the ballpark of 460-520. But I guess it also depends on what your using your truck for and if you need a detroit in the front.
  4. angrysnowplow
    Jan 8, 2002
    502
    MA
    Called him...#2 set has 9,000 miles on 'em. I am so all over this /forums/images/graemlins/grin.gif
    Ryan, he's got a $600 4.10 Dana 60 to match your rearend...I'm gonna go pull the covers off tomorrow- lemme know if you want me to check it out /forums/images/graemlins/thumb.gif
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if it was me id be all over this one /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    That's a great deal, is this through a friend or something?
  7. angrysnowplow
    Jan 8, 2002
    502
    MA
    [​IMG] Published every Tuesday. /forums/images/graemlins/thumb.gif
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I would go with number 2. But thats just me. Oh, and to find the gear ratio, look at the stamp on the ring gear. There will be a long vin number thing, the date it was made, and two numbers that are the r&p. Divide the high number by the low one, and you got the ratio. /forums/images/graemlins/thumb.gif
    -Harrison
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,139
    14
    Bangor,Pa
    for 2 hundred dollars more i would definitely go for number one.the detroit for it is like said 400 dollars and then you have to reset the ring and pinion.so anether 400 for that.so for 800 dollars you will be locked front and rear or spend the 200 dollars now and be done with it.if i had the cash id go with #1
  10. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    depends on what kind of lockers these all are. could make a big difference in value.
  11. angrysnowplow
    Jan 8, 2002
    502
    MA
    He says all his stuff is military (definitely explains the low mileage) so I believe they are all Detroits /forums/images/graemlins/thumb.gif
    87BrnRsd- Will do, thanks /forums/images/graemlins/thumb.gif
  12. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    # 2 is what I'd choose unless the front is a selectible locker. /forums/images/graemlins/eek.gif
  13. angrysnowplow
    Jan 8, 2002
    502
    MA
    I hear ya, I've never had a locker before (let alone a front locker)and I'm pretty sure the first time I drive in the snow there will be some casualties /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    Truth is I don't think I need a front one.
  14. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    #1 would be the better deal if the 60 locker is a Deeetroit but since you said that they're military surplus it's probably a 60 w/ a TruTrac(I think) that came out of a M1028(military K30 shelter carrier) or a M1031(cab/chassis).
  15. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I thought the military D60's that were 'locked' were Trak-Locks (Trash locks)/forums/images/graemlins/thinking.gif
    Rene
  16. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    If they are military, then I would definitely go with #2. The front in a military is usually the trac-lok, so unless you're ok with an LSD front...
  17. angrysnowplow
    Jan 8, 2002
    502
    MA
    Are non-locked military front axles limited slip?
  18. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Non locked military fronts are...not locked, as in open diff. Throw a Lock Right in there and call it good./forums/images/graemlins/thumb.gif
    That is my plan anyways.
    Rene
  19. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, that's it. I couldn't remember what the hell they were called... [​IMG]
  20. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I need set #3 REALLY REALLY BAD!!! Do you still have that guy's phone#????? If he's still got anything send me a PM, or just send me the # and I'll call myself. Thanks /forums/images/graemlins/thumb.gif
