Another High Mount Tie Rod Question
Discussion in 'The Garage' started by nvrenuf, Nov 28, 2003.
  1. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Sorry to beat this subject to deat but...
    How big of a lift can you go and still go with the high mounted tie rod? I've been looking at pics on the net and in magazines and most are of trucks with what looks like 4" or 6" springs. I currently have 10" springs but want to go with 8". Can I go with 8" without tie rod vs leaf spring interference?
    TIA!
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Shouldn't you be actually working instead of surfing the web ?????? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  3. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I am running 8" on my K5 and I don't have any problems. I am not even running a 1" spacer b/w the knuckle and the arm.
    Hope this answers your question. /forums/images/graemlins/thumb.gif
  4. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    That's exactly what I wanted to know! THANKS!! /forums/images/graemlins/cool.gif
    BTW - TARussell, instead of harrassing me shouldn't you be ordering a Doubler?! /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I just want to know why you have the avatar you have????????????????????????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  6. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    /forums/images/graemlins/rotfl.gif I saw that freaks mug shot and couldn't laughing so I thought it might do for a while. To be honest, now evertime I see one of my posts it sorta creeps me out. /forums/images/graemlins/eek.gif I'm currently looking for something more "normal" to replace it with, the wife saw it and said "The pedophiles got to go!". /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I told you that you needed help when You showed me that picture . Ha , ha /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    You know, it might make a nice avatar for you too. /forums/images/graemlins/grin.gif
  9. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    You are truly a very disturbed person ! /forums/images/graemlins/rotfl.gif
    Don't even think about it ! If that Freaks picture shows up on my name I just might make a mistake and accidentaly put 3.73's in your Crew Cab when we do a gear change ......
    " You can think about it , but DOOOOOOON'T do it " A qoute from Jackie Gleason from Smokey and the Bandit .
  10. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Oops almost forgot, Shagnaz what brand of arms do you run? Do you have TRE's or heims?
    Thanks again!
  11. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    I run 8" springs with high-steer also - no spacers here too. I use factory tie-rod ends. The arms are something we designed and had laser cut.
  12. Shagnaz
    Jul 19, 2002
    308
    I use Poison Spiders arms with TRE's
    The trick...get a 82 K5 Tie rod and then get a ES2026r and a ES2027L. They should tread right in and you are set.
    GM uses a 7/8-18 tierod end. I used a short K5 tre and a Dodge left handthread tre. The tapper was wrong, so I called Poison Spiders and they gave me the tre's to use.
    Good luck! Hope you like that trick instead of having to do some fab work.
  13. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    VERY KEWL!! THANKS!! /forums/images/graemlins/thumb.gif
  14. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Are there any interference issues with running the high mount tie rod and unmodified Hummer wheels on dually axles? I figured no but I want to make sure.
