Another Hummer Question
Discussion in 'The Garage' started by willymonster, Dec 25, 2006.
  1. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    does anybody know if you can run bias ply swampers on the radial hummer beadlocks ? i have come to find out there are radial and bias ply rims , im thinking it wont make a difference but i would like some more info before i pick these up . thanks:confused:
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Doesnt make a differance
  3. willymonster
    Feb 18, 2006
    183
    PARADISE,CA
    right on thats what i was thinking to . why are they different ? maybey the radial rim has less bolts because the sidewall wouldnt be expected to flex as much . im not sure which these are but hopfully the ones with more bolts what about mounting a 44 inch bogger on them without widening ? trying to save money we just bought a new house :laugh:
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    It's air pressure difference. 8 bolt limit is 35lbs and 12 bolt is 50lbs. The 12 bolts are hard to find. Backspacing is 7" so be sure you take that into account as well.
