another hydro clutch question
Discussion in 'The Garage' started by beater_k20, Feb 12, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    my buddy's TH400 took a crap on him the other day in his 87 R30 Dually, so he's looking to put the spare 465 he's got laying around in it. he wants to convert to a hydro clutch, since he has the pedals laying around. i've located a bellhousing for the project. will the mechanical clutch fork work? or will it need to be changed? how about the throwout bearing?
  2. dyeager535
    26,979
    Both the throwout bearing and fork are hydraulic specific unfortunately.
    But they shouldn't be that hard to find even new, nor very expensive.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've looked up part numbers for the swap, and have found all but the hose. anybody got the PN for the hose?
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I was looking for a hose 2 weeks ago, the only ine I found was at the dealer for $85. I found the pn on this site somewhere( sorry dont rember it). I ended up getting one made localy with a replacable 10000psi hyd hose for $65.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    lmc has em cheap
  6. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    A mechanical fork has a foward offset in it. The hydraulic one is almost flat across the body.The ball stud has a grease hole, I have a spare in a factory bag if you need that number.
  7. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    I got my hose at the dealer too. I figured it it was worth the piece of mind
    napa could also make one if you have the specs
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i thought the throw out bearing was the same between hydro and mechanical. i know there is a difference between diaphram and 3 finger bearing. the fork is different though, hydro is flat, mechanical is bent toward the front.
    the line i bought at carquest for $55, had to order it, but had it the next day, don't know the part number
  9. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    Hydraulic Hose (master to slave cylinder) GM#: 15537760
  10. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Not to hi-jack, but is the hydro bellhousing the same between 2 and 4 wheel drive, or are there 4 wheel drive specific bellhousings??
    Thanks.
  11. dyeager535
    26,979
    $48.50 from gmpartsdirect. Probably $60 after shipping, still less by far than the local dealer, no big surprise there.
    Parts manual says 15590168 for the bearing, but GMPD says it's no longer available. At least you can compare with older if you can find a non-hydraulic part number.
