Another hydro clutch ?
Discussion in 'The Garage' started by 79Jimmy, May 2, 2006.
  1. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    This is probably a dumb question, but I'm getting ready to swap over to a hydro clutch using all junkyard acquisitions:D and I was just wondering what if anything keeps the release/throwout bearing from riding against the pressure plate fingers when the clutch is "out" ? It should be up against the tranny on the input shaft bushing when in the "resting" position shouldn't it?:confused: I know on my '79 I have a spring which attaches to the fork and forward to the frame to keep the fork and thus the T.O bearing in the rearmost position. Is this accomplished by the nature of the hydraulics?
    In the slave cylinder there is a spring which sits under the "shuttle" in the cylinder keeping it extended thus pushing on the fork thus making the T.O bearing ride against the fingers all the time.....At least that's how I'm seeing it. Probably a very simple explanation:doah: Perhaps I'm over anylizing and should just put it in, I just like to know how things work and want to do this right the first time.
    James
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I wondered the exact same thing when I did my swap and I couldn't find an answer. Mine has worked fine for about 10K miles now with no noises or weird feel. Any clutch gurus out there who can educate us on this?
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I'm no guru but I set up my T/O bearing so it does not touch the P-plate's fingers when released. I put a spring on the fork to make sure it pulls away from the P-plate about 1/4" or less. I belive this will extend the life of the T/O bearing.
    .02c
  4. 79Jimmy
    May 10, 2000
    214
    Richmond BC, Canada
    Thanks for the replies guys and the pic Burt! That's prolly what I'll do with mine as well. I was, and still am, just curious as to why the hydro doesn't have a hole in it for a return spring to keep the T.O bearing off the preassure plate fingers. I agree that setup should extend the life of the bearing.
    James
  5. Burt4x4
    6,854
    Ya no clue on the factory GM hydro setup.
    I used Advance Adapter's slave mounting bracket to my old cast bellhousing. That slave you see is from a Toyota LandCruzer. I mounted a GM master to my firewall and driled a hole in my clutch pedal for the push rod.
    My manual linkage was set up to keep the TO bearing off the fingers too so I figure it must be the prefered way to doit :D
  6. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I bought a 1985 fullsize GMC Jimmy for $100 so I had EVERY part I needed. Can take pics if ya like... but the factory setup is awww so sweet......
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Yeah but factory hydro clutch trucks arent exactly common, and burt used off-the-shelf parts that anyone could. His probably wasn't that expensive either. Or do you just hate the thought of a Toyota part on your truck?:haha:
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I use a local clutch rebuilder instead of the parts store. He told me when I was doing my swap that you use a different throwout bearing in a hydraulic application.
  9. 79Jimmy
    May 10, 2000
    214
    Richmond BC, Canada
    I think he may have been referring to a hydraulic throwout bearing which is a totally different animal. From what I have looked up so far, the T.O bearing on the SM465 never changed when GM went to hydro in '85 FWIW, I could be wrong.......
    James
  10. dyeager535
    26,980
    Napa shows same part number for both hydraulic and mechanical clutches.
    15590168 was the GM number, I believe disco'd.
  11. RootBreaker
    Nov 29, 2001
    5,118
    173
    yoda part... that would be cool....
    i have edlorado parts on my truck..... :p:
