Another idea for interior of Blazer
Discussion in 'The Garage' started by badmix, Oct 15, 2006.
  1. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    73k5blazer's modifications from an old post got me thinking. I know he used alumibrite and made his own side panels for the back. But has anyone done this with lil hinges and doors to use that space for cargo, Nothing heavy jus maybe some jumper cables and gloves, etc. Also has anyone done anything like this with the stock particle board type cardboard that we have?
    Jus wondering. I know alot of ppl that gut the inside, jus yank that, but itll be along while before I gut mine (dunno why but its something I jus cant do. lol).
    Anyways, jus thinking outloud here. :D
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    i too thought about this and i still wanna do it. you could put yer staps,chains, d-rings. what ever in them.
  3. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    I might cruise by LOWES and see what materials i would need. I really wanna do this (plus gives me something to do and keeps me busy. lol). I figure all I need is a hinge or two. and some way to lock or secure the door part. Cutting it isnt a problem, jus use some kinda saw. Not sure how the vinyl cover would hold up. I suppose scoring with a razor blade first would help it not get bound up in the saw.........
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    that's my plan for this winter!
  5. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    You goin to use the factory side panels?
    What sections are you goin to be cutting into?
    Im thinking of around the wheel well area and back by the rear speakers.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    actually, i don't have any side panels, but i'll be building some. what i want to do is include some of the following ideas from greg72's rig, and build some tool boxes into these side panels, which will be flush with the bed rails like stock. i'm also going to include a skinny long locking compartment which goes from the back to the cab for holding longer items like the rails i will be using to support my other winter project (custom soft top!).
    greg72's rig:
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm only going to do one sub, the other will just have storage space. :)
  8. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    wow..that is really slick. Be cool to do something like that all the way to the back with lil compartments. Im sure someone could make some money if they could keep cost down on a project like that.
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm reluctant to lose bed space, thus i want it flush w/ the walls.
  10. JC_
    JC_ Registered Member
    Sep 21, 2006
    98
    Indiana
    Anyone have pics of this sort of thing?
  11. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    Not sure anyone has actually done it.
    I know some have made panels and mounted stuff to it, but to actually have access doors.
  12. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    i was actually thinking about doing this exact thing in mine... i am putting the interiour back into mine and was thinking about making custom panels for the back with little doors in them. but i decided that it would not be worth the time for that little bit of space.
  13. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    Well, if ya seen how much crap I carry.......lol. Im goin to maul it over some and see what I can come up with. Part of the problem is I have a 5 gal. water can mounted infront of the drivers side speaker and the gas nozzle thingy is in the way on the pass. side speaker location. So, ive got some limits. If I do it high on the wheel well, anything could slide down low and be a bitch to get to. so I may do it right beside the gas can using part of the wheel well.......( im jus rambling now arent I? LoL)
  14. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I plan on doing this and have been thinking about it for a while. I plan on using 1/16th aluminum sheet and making it wider in the rear so I can fit more stuff in it. Tuffy actually makes these now. Dont think they would fit in a K5 though.
  15. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    I would like to see more pics of that
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm not going to use much metal - i think i'll use a wood frame and something similar to masonite for the face. then i'm going to cover it in speaker box carpet so that it's not echoey in there. i'm going to brace all the doors so that they're firm - might use metal for that. anyway, it's my winter project, so i'll start in sometime after i finish the soft top, as the soft top will determine the way i make the storage space in the rig. ;)
  17. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I had to replace mine once. Do not use any material similar to MDF or masonite if you have any leaks. I used masonite (peg board without the holes) and discovered I had a slow but constant leak on the sides near the cab. Ruined all the work I had put into them. I did however add some dividers at the top each side of the wheelwells to stop things from sliding down them. (I put access doors on each side.) For the back I put a small door for loose items like jumper cables and tow straps behind the spare and a larger one on the other side. I used a continuous hinge for each one and a little hasp type closure. Worked well enough for my needs. No pictures though, sorry.:rolleyes:
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Some kind of hasp , or folding latch that takes a lock . Instead of the lock though , use a hitch pin , unless its an open top truck , then use a lock :)
  19. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I was going to do that with mine, but they are full with 2 Amps, 1 10" sub, 1 500w inverter/charger, 2 6" speakers., 120v AC plug, AC swtich to engine block heater, all associated wiring. There's probably a little room in the front area of the right side though.
    It is a good idea though.
  20. quicker
    quicker 1/2 ton status
    Jul 12, 2006
    168
    CA
    I had the same idea and figured the aluminum choice is ok if covered with paint or coating to reduce the chance of getting burned by sun heated aluminum. I plan on taking off the top so heat becomes an issue.
    Quick
