another LIFT KIT question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The85k5, Mar 6, 2001.
  1. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    I have a 85 k5 with stock suspension, i've been looking around for the past few months for kits and i've heard great things about superlift, rough country and pro comp, the thing is i can get a good deal on pro comp through my work, but is the lift a good quality and am i getting a good deal? i'm buying a 4" suspension i've decided and for the pro comp its gonna run me about 525 after tax for 6 3000 series shocks, 4" blocks, U-bolts, Springs, and the steering arm. now is this a good deal or should i keep looking? i want a quality lift (not too stiff) for a decent price.
    please help me out
    thanx
    Robb
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Well if you strictly want a show rig then blocks will do. If you plan on actually getting offroad and wheeling your rig then you'd want to stay away from lift blocks. ORD sells a shackle flip kit to give you 4" of lift from the stock rear springs, then you could do the tuff country EZ rides up front. I run that setup and love it. I had a Rancho kit before and it sucked big time. Feel free to message me for more detailed info.
  3. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I have a set of ORD brackets that I'd be willing to sell you. When I needed rear springs I decided to change the mounting locations etc. The kit works really well and is very sturdy.
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm not sure how expensive the shocks are, but you can get a 4" lift with blocks for $295 from Rough Country.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  5. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I picked up my 4" lift from Rough Country for 250.00 and it came with shocks. Then added the ORD Flip. Paying over 500 for a lift without rear springs is a little to pricey for me.
    85 Blazer on an 82 chassis, 6.2L Diesel, ORD flip, 35's with no cutting on a 4" lift.
  6. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Rough Country is running a 4 inch Lift special for GM trucks.. it comes w/ front/rear springs, 4 shocks, steering arm and all the hardware.. I paid 550.00 total .. that included shipping.
    The special is on the main page of Rough Country
    http://www.rocko.coloradok5.com
  7. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> If your are gonna run 6 shocks, the Rough Country shocks are $32.95-34.95, depending on which ones you buy.
    <font color=green> I love cowboy hats
  8. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I'd run the rough country before the PRO comps. The pro-comps are supposed the be the stiffest out there. I run the skyjacker softrides. I like the bouncy air ride though. It sucks for drinking and driving, LOL!!! Not beer man. Just any liquid out of an open container. You better get a bib. LOL!
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  9. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I've been running 4" Pro Comp front springs, 4 Pro Comp shocks, and a U-can't-afford-it shackle flip for 5 years or so, its sagged to about 3" and flexes really well, I pulled a 1440 on a 20 degree ramp in Moab last year. My experiece has been that the springs are pretty soft (and can be a tad bouncy). I would recomend them, but I haven't tried the others. In general, there is a big difference flex wise between a 4" and 6" spring.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I did the 4 inch Rough Contry and have only one complaint... The crumby brake line brackets... I bought the Stainless Steel lines and popped them on...
    I am doing a 4 inch shackle flip next... I dont want the blocks ... I'm afraid going over the speed bumps at 40 might crack one...
    Any one know how the shackle flip will effect the driveline angles? I know the blocks are shimmed to help correct this problem...
    Um... yes officer I know it's too big...
  11. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    A shackle flip will generally require you to shim the pinion DOWN. While I'm not a block fan by any means, if they are installed properly they shouldn't be a huge safety issue. My Dodge has 4-3/4" blocks from the factory, I've seen up to 6". However, OE blocks are usually cast iron and often have extra provisions for holding them in place.
    Pete
  12. Waxer
    1,857
    Long Beach, CA.
    I did the Shackle flip on my 74 K5 with a 14 bolt and I didnt have to shim anything down. I get no vibration at all and much much flex.
  13. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have a Pro Comp 2.5 inch lift, and it's too stiff... I would go with a Superlift 4 inch spring lift in the front, and a shackle flip in the rear...
    <font color=blue> I'm down with the clown, till I'm dead in the ground.</font color=blue>
