ANOTHER locked vs. open axle question.
Discussion in 'The Garage' started by TruckNutzDude, Jun 17, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I know this has been covered so many times most of you won't even bother reading it. Anyways, here's my problem, I need to change the carrier in my front Dana 60 when I install my 5.13 gears and money is tight at the moment. I'm building my rig to be beaten on some fairly tight trails, rocks, snow in the winter and a lot of mud (mostly mud /forums/images/graemlins/waytogo.gif) I have a TBI 350 engine, SM465 tranny with a 205 and 39.5 inch Boggers. I have a few options for my front end. I could use a ring gear spacer until I can afford a locker, or install a spool and unlock a hub when I need to turn. I also need to lock my rear axle but I've been afraid to weld it because I see moderate street use and those Boggers are WIDE. I don't want a detroit because the last one I had (with an auto and 36 inch tires) didn't seem to unlock around turns (lead foot) and had some torque steer on the highway. What would you guys do?? /forums/images/graemlins/confused.gif
    I forgot to add some options to the poll. Who would suggest a welded rear and a detroit up front or welded front and rear?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i would go open front and welded rear, its cheap. plus when you get enough money for the detroit, it will replace them.
    BTW, now i have a craving for some cheetos /forums/images/graemlins/doah.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Your expirience with the detroit is wierd... I barely know mine is there... I can make it chirp around a corner if i want to but thats under my control most of the time... Id give the detroit in the rear another shot,
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    ...I'm building my rig to be beaten on some fairly tight trails...
    Leave the front open for now. /forums/images/graemlins/waytogo.gif
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    detroit/detroit.
    j
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    detroit/detroit.
    j
    That's what's going up front eventually. I was thinking about one of the electric lockers that acts as a limited slip when it's not activated. I just can't figure out if I want to leave the front open or spooled until I can afford that.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Being locked up front now I would have welded it years ago rather than go with it open.
    I say weld the front for the time being, don't spend any money on a spool.
    If you want to spend money buy a lockright.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    detroit/detroit.
    there is no other option
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    detroit/detroit.
    My truck sure seems to think that there is. /forums/images/graemlins/rotfl.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    arent you the same lad that was claiming '10 bolts are 44" tire resistant, my friend runs them and never breaks' not to long ago
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Locker good , Locker good . Stuck is bad /forums/images/graemlins/waytogo.gif
  12. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    /forums/images/graemlins/rotfl.gif Don't you have a power-loc in your '60?
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    [​IMG] /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  16. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I personally think it's a waste to swap in 1-ton axles, regear them, and then leave them open.......unless your plans are just mall-cruising /forums/images/graemlins/whistling.gif
    The ultimate budget plan, in my opinion, is a welded rear and Lock-right front. I had my rear axle welded, for free, thinking "if I don't like it then just slap in a Detroit"......3 years later it's still welded in the back.
    For the front, I just couldn't bring myself to weld it after seeing a couple of guys in our club try it. Seeing them have to get in and out of the vehicle constantly to unlock and lock hubs didn't seem like much fun. Also with a welded front shifting the t-case into 2wd doesn't help much either. With my Lock-right front there was very little difference in turning on the trail while in 4wd as compared to my old limited slip front, and shifting into 2wd for 3-point turns completely defeats the locking mechanism also.
  17. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Lock_right front, weld rear, because your on a buget now.
  18. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I run detroit rear and welded front, I wouldn't change it for anythign else.
  19. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    What about welding the rear and running a detroit up front? Will I be able to turn without unlocking the hubs? And how will the street manners be with the rear welded? Feel free to make more suggestions /forums/images/graemlins/waytogo.gif TIA -Rob-
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Street manners are going to suck with boggers anyway so that should be the least of your worries.
    As to detroit or lock right up front with a welded rear, I would certainly say that's a great combo (and what i would be running today had I not got a great deal on this rear axle). /forums/images/graemlins/thumb.gif
    Yes you will be able to turn just fine. I don't really understand why everyone whines about the steering effort that a locker adds.....it's very minimal.
