Another Newbie transfer case questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sickquad, Aug 21, 2003.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Besides strength does a np205 have any advantages over a 203? I just picked up a free np205 and currently have a 203 in my truck. This rig will be a daily driver as well as see trail use. Also will a 205 bolt up to my 700r4? Thanks for any input.
    Chris
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Strength is the biggest thing the 205 has over the 203. As far as bolting the 205 to the 700r4, it can be done if the 205 is off a th350. You will have to buy a special adapter or a different out put shaft for the 700r4.
  3. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    If you're using this for a daily driver, the 205 is a part time four wheel drive not full time like the 203. So in saying that you will get better gas milage with the 205. I was going to convert my 203 to a part time, but it would be cheaper to buy a used 205.
  4. sickquad
    Jul 23, 2003
    785
    Ma
    So, from a search of the board I came up with A&Reds Trans Parts posted by Batmanjr. They are supposed to have the adapter plate for the 700r4 to np205 connection. But I called and they said they don't make them. Did I just talk to the wrong person? Anybody know of a different place to get this? Or does someone have one to sell?
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    part time cases are better for constant on road driving, and are gear to gear driven with no chain to worry about, unlike in the 203 and 208's
    205 is best alll around case, for strenght and driveability, technially
    definitely go with 203 over a 208, however ! unless you have new chain put in first, then maybe, but dont shock drive it
    good luck
  6. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    The 205 beats the hell outta a 203 in driveline length aswell. The 203 is a good case, its just not the best.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Except for the crappy low range... A 208 or 241 would bolt right up with the correct adapter. No changing the output shaft for the tranny. If it were me, I'd go with a 241 unless your wheeling is VERY hardcore.
  8. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Unless you have a specific need, go with the 208.. syncronized, and you can lift it in and out with one person..Just make you get the linkage, it bolts to the floor....and the driveshafts, the front is longer, the rear shorter..(may be close with a 205 though...) /forums/images/graemlins/cool.gif
    The 203/205 takes 2 men and a boy.. it is realy, realy, realy, realy heavy....
  9. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I don't know what a 208 and a 241 has to do with this post..........doh
    A 205 would be a good alternate to the 203, but you have got yourself an excellent opportunity here to convert over to a doubler.
    Click here for info on a Doubler
    Click here for an adapter for the 700/205 combo.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. sickquad
    Jul 23, 2003
    785
    Ma
    I should have looked at Advance Adapters first, they have good information there for GM trucks if anyone is interested. My first time seeing it.
    No need for a doubler. The point of my Blazer is for light trail use. There isn't anything nasty enough around that lockers won't get you out.
    Thanks for the info
    Chris
  11. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Anytime /forums/images/graemlins/thumb.gif
