another Np208 going south
Discussion in 'The Garage' started by adamforsythe, Apr 22, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I believe my NP208 is going south.....it's making noises like what you would hear if you put it in 4 low. The only way to make it go away is put it in 4 low go foward then put it in 2wd and go backwards. I have a NP205 in another truck that I just have to drop. BUT This truck is a 1979 GMC truck with a standered. What would I have to do to mate it up to my Th350?
    Adam
  2. 74poj
    74poj Registered Member
    Apr 12, 2005
    46
    Montana
    the 205 on the standard should have a 10 spline input shaft, usually the th350 has a 27 spline output. as long as you have the right adapter you should only need a 27 to 10 conversion. check out advance adapters, the 27 to 10 is reasonable. or just swap in the whole tranny/t-case combo!:D
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Some guys change the input shaft of their 205 when they go doubler .
    Post up for a 27 spline input , and th350 adapter in the wanted forum . Someones going to have the parts somewhere .
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
  5. 74poj
    Apr 12, 2005
    46
    Montana
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
