Another on-board air compressor alternative
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Mar 11, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i was going to post this as well
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    your typical sanden ac compressor is supposed to work real well
    guy on POR said he has run one for years with no oiling
    I am going to try that route
  4. BurbinOR
    5,829
    Oregon
    Do you have a link to a 'Sanden AC compressor'? I'm open to exploring all options before I go with something, but am I getting that right, it's 'AC' power?
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    ac = air conditioning
    sanden is the common compact multi cylinder aluminum compressor
    http://air-tique.jeepgear.com/osb/showitem.cfm/Category/113
    <a target="_blank" href=http://www.justaimlinks.com/compressor_belt_eng.htm>or even the one on the above listed site that he doesnt tell you its a sanden</a>
    every junkyard will have tons of them as they are super common
  6. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    You are correct, the Sanden type compressors work very well the only issue being oiling. I pour about 1 OZ every 3rd trip out to oil mine and I have been running it over a year now.
    Check out my link with pictures of the compressor and setup in my fist gen blazer.
    <a target="_blank" href=http://coloradok5.com/gallery/Robzilla-Photos/aaa>http://coloradok5.com/gallery/Robzilla-Photos/aaa</a>
    Robzilla
  7. BurbinOR
    5,829
    Oregon
    Now that's what I call a brainlock...........anyway, I'll keep my AC operational and add either a PowerTank or 12V high volume/high pressure.
    Thanks tho.
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  9. BurbinOR
    5,829
    Oregon
    How do you have your's mounted............on the fenderwell or where? You got the same one (4CFM for $279 one)?
  10. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    Frank,
    My standard AC still is operational, I added another compressor with a custom mount. I have two under the hood.
    Robzilla
  11. BurbinOR
    5,829
    Oregon
    Thanks, I'll check out your webpage about that..............figured in AZ you wouldn't go without it............tho when I lived there, in the 8 years in the Valley, I had AC probably 2 years..............
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  13. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Check these out. I saw them at an offroad event and they sweet(but expensive!).<a target="_blank" href=http://oasis-off-road.com/page4.html>http://oasis-off-road.com/page4.html</a>
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I could be wrong actually, it was the GM a6 that i found on a pirate search.
    teflon pistons...
  15. BurbinOR
    5,829
    Oregon
    Cool, thanks...........
