Another one bites the dust!
Discussion in 'Pacific Region' started by 55Willy, Nov 21, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    motor #2 just parted ways with my Bro's 79 Jimmy.
    the first motor he drove home in low rnage only to wake up to a rod knocking..
    motor two left us last week. the belt came off the water pump, blew the pump and after swapping a new pump on... head is cracked or blown head gasket, white smoke out the one side with the hint of oil and antifreeze in it....
    SSSSssssssssoooooooooo......
    the motor from the 1950 Truck is going in it /forums/images/graemlins/pimp1.gif
    were talking 400+ horse.
    Tranny will be replaced at the same time sinc eit is on it's way out too.
    I think he has had it about a year or so.. two motors..
    gees when I had it for the year it was driveable all i did was toast the tranny, tcase, front axle and engine,LMAO!!
  2. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    wow sounds like somebody is a little hard things /forums/images/graemlins/eek.gif
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    hey, let me know if you need another 400+ engine, I have one sitting on my garage floor for sale /forums/images/graemlins/thumb.gif Its only got a few thousand miles on it.
  4. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    hey topdown how about you list some specs and a price for the rest of us????? /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Topdown
    Nov 26, 2002
    2,598
    ok... lets go from the ... top-down
    Holley 670 Street avenger carb, tuned to the engine
    Edelbrock air-gap intake
    Trick flow angle plug heads 2.02/160 - Kick Ass!
    - comes with spark plugs
    1.6 ratio aluminum full roller-rockers - roller tips and fulcrum
    Comp Cams Magnum push rods
    hardened steel guide plates
    double roller Comp Cams timing set
    Comp Cams xe268 extreme energy cam - nice lope, still gives lots of vacuum for brakes and whatnot
    4-bolt main block bored .030 over
    Keith Black Hypereutectic(sp) pistons with chromoly plasma-cut rings
    GM "pink" rods
    SCAT forged crank shaft
    7-quart moroso oil pan with high-volume pickup & windage - hangs maybe 1" lower than stock but its much wider
    stock volume cast long neck water pump
    Needs a flex-plate (I stole the one off it /forums/images/graemlins/smile.gif) and a distributor
    dyno'd at 410hp and 425tq (its either 425 or 435 torque...)
    needless to say, it SCREAMS...
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    dood thats almost the same motor he has his except he has forged pistons and a bigger cam. tuned so it idles is 400-420 hose.
  7. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    sounds good how's 10 bucks sound? /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'll give ya $25 for it /forums/images/graemlins/thumb.gif
  9. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i think the LUV needs that motor /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  10. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I'll give ya $25.50. /forums/images/graemlins/rolleyes.gif
    -Andrew /forums/images/graemlins/usaflag.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. clubba68
    Dec 6, 2002
    1,511
    Haha! Screwed you again Jeff! /forums/images/graemlins/thumb.gif
  13. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    That was down, or Topdown, right punny... /forums/images/graemlins/thinking.gif
  14. Topdown
    Nov 26, 2002
    2,598
    There are about 3500.00 worth of parts, not including labor of building the thing, tuning it, etc... so I would be willing to part with it for right around 3500.00 give or take a few.
    -R
