another one bits the dust, just another blown up 10 bolt!
Discussion in 'The Garage' started by bablazer73, Jan 22, 2003.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    This is out of a friends plow truck.It's his front diff. [​IMG] I was hoping to save the 3.73 gears but allwell!!
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I scraped the parts out of the first 10B rear I blew up with screwdriver.Called friend with wrecker to get home.Carrier was totally gone,nothing to hold axles in.Was ahead of 86 Trans Am{friend helped with rescue},35 Gumbos and snatching 2nd doesn't help 10Bs. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I blew up my first 10-bolt in '95. I was out mudding and the Gov-loc gave up the ghost and took the spiders with it. Then I shredded a ring and pinion and '98 and '99 /forums/images/graemlins/mad.gif. I also broke my front 10-bolt in half where the axle-tube meets the chunk. I hit a big rock-berg (2' up, 10' below) which bent the tie-rod into a U, broke the axle tube out, broke the axle, smashed the oil pan with the chunk, drove the drive shaft into the t-case which cracked a case half and smashed the tranny adapter into three pieces. It also bent my frame behind the steering box!! /forums/images/graemlins/shocked.gif Check out the carnage on my website! I am finally going to replace my POS 10-bolts with my 14-bolt/Dana 60 this winter. It takes some folks a while to give up the ghost! /forums/images/graemlins/rotfl.gif
    Chris /forums/images/graemlins/rolleyes.gif
    The rock that did the damage:
