another Q-Jet adjusting question???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Mar 24, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    OK, got the choke fixed and also got the secondaries working(was a spring problem) but they are opening immediately...you stomp it and they open as if they were manuals....so i noticed this little set screw in the back of the vacum pod and am wondering if this will help adjust the opening quickly problem, or do you change the springs...it has the ones it came with on it they were just un hooked ...thx appreciate the continued help with the quadrapuke...LOL
  2. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    There is a screw on the passenger side back by the secondaries that, when tightened, increases tension on the return spring for the air flap thingy covering the secondaries. Just look around the bushings for the secondary air flap (not the actual butterflys) and tighten it up a bit. That is how you adjust how quickly the secondaries open up. It takes a little more vacume to pull it open that way. I think stock is about 2 and 1/2 turns out if I remeber right.
    Sparky
    PS look carefully cause its pretty small.
