Another Quadrajet Problem....anybody??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Aug 20, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Where do i start, ok it stumbles when you stomp it, it's like a manual secondary just dumps them immediately! Then when you stomp it at 3800 it starts kind falling out and stuttering, it will open the secondaries for a little bit then start falling out and running bad wont really get highr than 4500, kind of slight jurks almost like the fuel quits flowing or doesn't flow enough. Kind of feels like the valves are floating''
    Has a good ignition, pump and new filter, z-28 springs everything pretty much new, The springs and lifters are new and should hold up to atleast 5000 before they start floating or varying. It will run smooth after the initial stumble up to about 3800 then starts this....I am really puzzled. some help would really be appreciated. THX
  2. bUrLyBlAzEr89
    bUrLyBlAzEr89 Registered Member
    Jul 10, 2002
    47
    Nipomo, Ca
    uhhh.......if its tbi make sure no leaks they need alot of pressure and clean up your carb/tbi if still probs get it rebuilt
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think you're describing the famous quadra-bog.
    This happens because the secondaries open either too quick or too slow. There's a tiny screw on one end of the secondaries' shaft. This screw tightens or loosens the spring that keeps the secondaries closed. If this spring is too loose, they will slam open when you floor it, if it's too tight, the valves will take too long to open.
    Turn this spring to adjust this tension until you find the right setting. Watch it because a little goes a long way on this little screw. Also, there's an allen screw perpendicular to the screw that prevents from turning loose, so loosen this allen screw first.
    I hope this helps.
  4. twenty_below0
    May 16, 2001
    436
    I will try this tonight after work, THX appreciate it I will let you know if it changes!
