Another question concerning snorkles and exhaust
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SlyDog, Dec 2, 2001.
  1. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    My dad is worried about the exhaust under water? If I install a snorkle would we also need to put the exhaust above water somewhere? Or is that not a problem?? <P ID="edit"><FONT class="small">Edited by SlyDog on 12/02/01 10:06 PM.</FONT></P>
  2. Boscolingus
    Boscolingus 1/2 ton status
    Nov 26, 2001
    210
    Santa Clarita, CA
    well - in experience relating to my M422 Mighty Mite, all that was neccessary to keep the jep running was that the intake and exhaust be above water, of course everything else was mil-spec water tight ( crank case, ignition, all electrical - i.e. solid state mechanical control box for the jeeps electrical system ) however I have seen off road guys using various trucks and jeeps in the off road mags driving through the water, but there is no telling what the had to do to make everything work
    Got my 91 K5 back after 2 years - and man I need parts - BAD!!!!
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    I know that my M37 came with a fording kit that set both the exhaust and intake above the roof line for swimmin'. It too had a waterproofed engine in it though. While you can run the exhaust underwater, the intake must be above (for obvious reasons) the pressure of the exhaust will keep it from backwashing (generally). If you stall however.....
    Why do people keep calling it a Bronco!!!!! [​IMG]
  4. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Anyone else ?
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
  5. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    exhaust is fine underwater-
    as long as you don't stall, or if you do, the waterlevel is not at or above header height....
    oh yeah the m715's came with a snorkeled intake, exhaust, and a lever to close the pcv valve, positively pressurizing the crankcase.....
    greg
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    The exhaust under water shouldn't be a problem, that is unless you kill the truck. as long as the truck is running you should be okay. IF you were REAL worried about it. just do a stack that could be quick mounted with some clamps.
    Kyle
    89K5
  7. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Thanks, thats what I wanted to hear [​IMG]
    BUILT NOT BOUGHT
  8. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    The main thing to watch is with the exhaust under water, that the level isnt above the head hieght. I have been stuck many times when I had to shut the truck down and the exhaust was under water. I never had any troubles, but the water level was below the head level.. A V8 wont have any trouble keeping enough pressure out the exhaust to keep running, my Toyota had real probs when the tailpipe dipped under water!
    Mike
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Run single or w/duals, don't run a crss-over pipe. Or Make a low point in the exhaust - to trap the water. Like hang the mufflers with the entrence high, and out-let in the middle.
    At idle, and engine with a narrow Lobe-Seperation or exsessive duration (valve-over-lap) can and will "back-flow" slightly sucking exhaust back into the chamber. Probably not likely with a street cam, but something to consider, things change when your at idle with a free-flowing exhaust sys.
    <font color=blue>Twiz</font color=blue>
    Can't get it up?
    So, drop it in
    gear.<P ID="edit"><FONT class="small">Edited by Twiztid on 12/03/01 09:02 PM.</FONT></P>
  10. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    What my dad and I are thinking, since I have the complete exhaust out right now make a y pipe in front of the muffler so we can clamp it up if we run into water ... don't know how clear that is but I think it will work [​IMG] Thanks for all your input!
    BUILT NOT BOUGHT
