Another question for carpenters...
Discussion in 'The Lounge' started by 84gmcjimmy, Jul 13, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, for those who remember I am building a enclosure around my pool pump because of the noise it makes...
    I got all the walls framed and lined with plywood. Now I have to make a door.
    I have 44.5 inches from one side of the opening to the other. I am using 5" triangle (heavy duty) hinges for the door. Tomorrow I will be making the door, so i was wondering How wide should I make the door? I don't want it to rub when opening or closing. The hinges will sit on the out side of the plywoood, not sandwiched like some house doors are. And I also have to come up with a way to latch it so it stays closed. Any ideas on any of my questions?
    For those who want some, I will have before and after pics of the whole thing. Thanks for your time.
    Steve
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I'm gonna say 44 and 3/8" wide and since the door is openin out, I assume, you could use somethin as simple as a piece of wood that flops over or as complex as a hasp. Hope this might at least give ya a start. /forums/images/graemlins/thumb.gif
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    When I built my doors for both my sheds, I made the frame to fit snug(allowing 1/8th of an inch for hinges) and then trimmed it to fit. Only after the frame was right did I sheet the door. I also trimmed the door with 1x4 cedar to hide any imperfections.
    I'm sure there's a better way of doing it, however. I wish I knew what it was because on Saturday I start building my 12x12 shed and the sucker's gonna have double doors. I'm already having heart murmurs thinking about getting two doors to fit properly!!!! /forums/images/graemlins/doah.gif
  4. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I would say just build it like a gate (boxed out w/ 2x4's inside and sheathed outside) and buy a "gate iron" kit at the local HD, this consists of a couple of long iron hinges (20" +/-) and a handle for the outside and latch on the inside. I don't think that those little 5" hinges will hold up with a door that big and heavy unless you do some reinforcing and big ass fasteners, especially if you sheath it in something heavy (3/8 or bigger plywood i.e.)
    The extra long hinges tie into the 2x4 cross braces w/carriage bolts and give you a lot more strength for a heavy door, and no sag over time.
    That's my $.02
    And 44 1/2"-44 3/8" for door clearance probably.
  5. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    How thick is the door itself, and is it recessed fully?
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    The door is simply just a 2x4 frame with plywood on the outside /forums/images/graemlins/dunno.gif Around 50-60 inches tall.
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    give yourself a half inch around, How tall is the door/ i am thinking short for some reason, i think 5" hinges are plenty, build it how ever is easyest on you suplies or back pockit 2x4 frame with a cross brace to keep it from sagging should do, to keep it closed you could use anything a chunk of wood with a nail in the center is cheap and looks like crap a dead bolt is nice looking not to expencive but prob overkill, use a fence latch one side has a little arm the other a little latch so put the arm on the door and the latch on the frame , the is also a prevision for a padlock too.
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gifwhen your dont lets get the pics!
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yup the door is short, the deck its under is level with my head, so just under 6 feet. So I am guessing around 5 feet maybe. Around 50-60 inches like I said.
    OH CRAP! good thing you mentioned the cross brace, I was going to do that, but forgot all about it. Feewf! I still don't know what to do with the latch, those are all good ideas. desciions descions /forums/images/graemlins/thinking.gif
  9. Can Can
    15,552
    136
    If you go with 3/4 and up plywood you don't really need a brace. Both my sheds doors are braceless and haven't sagged in the last three years. I used a flat 2x4 gusseted frame and screwed the 3/4 ply to the frame every 4 inches. The thick ply acts as a brace. My doors are heavy enough without having an extra 2x4 in the mix.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That would probably be the easiest way paul, but I don't have any 3/4" plywood. And we don't really have enough money to spend 80 bucks to make it fit. (2 pieces, lengthwise, cut to fit).
    If I have a cross brace, is that enough, or should I have some studs too? If I need to incorperate studs into it, thats going to be hard /forums/images/graemlins/thinking.gif
