Another question.. what weight oil in differential??
Discussion in 'The Garage' started by XHitman396, Jul 22, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so what weight oil should i put in a 14bff and my 10 bolt front?? Ive never even bought any before, and the guy at the parts store triple guessed himself. so, whatcha got?? thank you..
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    80-90w
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I always just use 80-90 as well
  4. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    regular old 80-90 in an open diff is what i use
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i use 80-90. some guy who claims to build rock crawlers says that 80-140 or something works better in diffs with lockers. i duno if hes right tho.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    70-140, its synthetic gear lube. thinner, Mazda/Ford use it in their tcases(the Ford Escape/Mazda thinger). Yeah I say use 80-90, nothing wrong with it in any instance, just use limited slip additive when you have a limited slip diff.
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    check and see, most 80/90's have LSD additive.
    "consider" 140 if your going to be towing in hot weather. Synth is good, but if you play around a lot in water/mud, you'd be changing it all the time anyways.
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so if your plannin on taking a 275 mile trip each way to the beach, it prolly would be best to put in the 70/140 synthetic right?:) i just finished the break in period for my yukons/detroits so i need to change the fluids anyways.
  9. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'd stay with 80/90 the biggest reason for going to a higher weight oil is heat. If you aren't building a lot of heat in your diff (like when you do towing) just run 80/90
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    for a light-use rig / DD, what would be the best synthetic to use? My ranger has a tiny diff.. couldn't take much fluid and it hasn't been changed (as far as I know!) since it was built in 94...
    j
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    a long road trip would build up alot of heat right? would puttin 70/140 eliminate the need to stop frequently to allow it to cool down?
  12. resurrected_jimmy
    May 23, 2005
    2,241
    I think 80/90 is fine for your use. If you are having to stop to let your diffs cool then something besides gear oil is very wrong.
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright cool. well i only mentioned frequent stops because it was advice that was given to i believe it was avery bout driving like 200miles to the beach in cali.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if you gears are fully broken in, there should be no need to stop all the time. Now if they aren't done the break in period, yeah giving it a break is a good idea.
  15. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    So, is there any reason to not run 85W140? The manual for my Detroit says to use mfg recommend oil (80-90). The manual for my Lock-Right says to use 85-140 to reduce the noise. Figured I'd just go with the 85W140 in both since I'm in sunny Florida.
