Another rear disc brake question?
Discussion in 'The Garage' started by jwduke, Sep 27, 2003.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Ok all of you guys who have put rear disc's on your 14 bolt, Are the rear brakes tight after you put the calipers on the rotors?? Mine are, am I doing something wrong? I'm using Eldorado calipers & disc pads.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    what do you mean by "tight"??
  3. jwduke
    Aug 25, 2001
    721
    Well the rotor is hard to turn, guess this would wear off?
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Sounds like the e-brake adjustment is a little off.
  5. 85BlazerFan
    85BlazerFan Registered Member
    Dec 2, 2002
    14
    Audubon, NJ
    Can you turn the rotor by hand? If you can't, you'll more than likely warp your rotors due to the heatbuild up if you drive it this way.
    When I put my Caddy calipers on, it was SO tight, I couldn't budge the rotor. I took the caliper off, then used my concrete driveway to sand down the pads.
    Remember, the e-brake adjusts the caliper piston. If you sand down the pads, work the e-brake lever a few times to seat the pads.
  6. jwduke
    Aug 25, 2001
    721
    It does turn, but it is hard....... I don't have any brake levers, was waiting for Harry & Sean to come up with theirs. I've tried GM Parts direct, they dont have them anymore. Any ideas???
