Another Rear Window Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mxrcr589, May 24, 2004.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    When i roll my rear window up it gets sideways the right side doesnt go all the way up, the dang gears jump. Has anyone fixed this by making the 2 gear fit tighter or something??
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The gears on the regulator are swedged into place, they cannot be adjusted. Now the transmission that drives the regulator does have a little bit of adjustment in it. But what your saying, almost sounds like the regulator is wore out or slightly bent causing it to jump teeth.
  3. mxrcr589
    Apr 17, 2003
    148
    poop
    yeah thats what it does, jumps the teeth
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Did you try checking what I suggested yet? Updated us /forums/images/graemlins/thumb.gif
  5. mxrcr589
    Apr 17, 2003
    148
    poop
    i dont see where you adjustment is at /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    there is only a very slight amount of adjustment cause of the mounting holes, but it can be moved in or out just a tad. But if that isn't going to work, then you've got other problems.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Have you pulled the inspection plate on the tailgate and had someone run the tailgate up and down while you watch carefully? It might be that the actuator arms and rollers are not engaging the track on the bottom of the window sash properly and not pushing up on the window properly.
