Another rookie question?
Discussion in 'The Garage' started by Blue84K10, Feb 8, 2005.
  1. Blue84K10
    Blue84K10 Registered Member
    Jan 24, 2005
    15
    Seattle
    Ok well I followed the advice that I recieved from my last post and took my truck to Fosters Frame and Axle located here in Seattle. They told me that it would cost a total of 1,861.31 to get my tuck back on the road. 1029 just for the frame then another 441 to install the axels that I have purchased. and then some other stuff like the pitman arm and alignment... Is this a fair deal? I have no idea. I didn't even know what a pitman arm was untill he showed me. Also i have a six inch spring lift in front and blocks in back to be installed. I am asumming that I will need to purchase new shocks for my baby. What other problems ( or other things that will cost me money) should I epect to run into. I am trying to get my truck ready for Memorial Day Weekend at Moses lake so my project has some time left but I still have a long way to go!!!!!!
    Any advice would be wonderful or even links to where this might have been talked about before..
    Thanks again
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    If you're at all mechanically inclined, you can remove/install axles in a weekend. Personally I would do it myself. Its pretty darn easy and any help you need is right here.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    What are you having done to the frame that cost $1000? Swapping axles is a pain but is definetly worth saving $400:)
    You might need new driveshafts? Don't know if the 6" lift is already on or are you putting it on?
    More info would help.
  4. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I saw your other post about the frame being bent. Do you have a place and tools to work on it? You can buy a used frame for next to nothing and spend 2 weekends swapping your drivetrain and body onto it.
