another sacrifice to the cv gods
Discussion in 'The Garage' started by dogdaysunrise, Aug 19, 2005.
  1. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    Just curious, I have a 92 IFS k1500. I blew another cv-joint and dont want to replace it right now (no time to pull it apart) If i remove the half shaft at the flange and remove it at the outter cv joint, will I still be able to drive it as long as it is in 2wd? Im going to leave the stub shaft in so the bearings dont fall apart, but will I run into issues doing this?
    Thanks in advance,
    Mike
  2. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    I should also note, that the outter cv shaft has blow to pieces, so to take it apart i just have to cut the boot.
  3. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    Yep should work, just make sure you you have the stub shaft in there and the nut torked down tight
  4. sweetk30
    Nov 1, 2004
    25,551
    544
    horseheads , ny 14845
    that is correct.:D no stub shaft no bearings :p:
