another set back on the 68 burb
Discussion in '1936-Present Suburban' started by 55Willy, Sep 11, 2006.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    this so called rebuilt 400 i got... the valley and heads look clean, but when i pulled the water pump off rust came out, doesn't look like the motor was ran in years. intake seals look original..gross crunchy and very brittle.
    so time for a rebuild. i'm guessing it'll need to be bore,all kits I have found run the 5.7" rods vs the stock 5.56" rods. summit does have 2 that keep the 5.56" rods. with the 74 ish cc heads I have they will both put me in the 10 to 1 stage.
    should I just get some 5.7" rods and step down the compression? ( more piston selections)
  2. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Go to the wrecking yard... buy a waranteed used motor and put it in the truck
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    getting a 350 sunday. also maybe two more ( my dads old one out of his 91 burb and my friends 98 vortec )
    I have a set of Standard flat top 350's and my dart heads so I'll just build a hot little 350 and then build the 400 with a 415 or 434 stroker kit for the rat rod project.
