another shackle flip qeustion
Discussion in 'The Garage' started by BrownK5, Mar 8, 2006.
  1. BrownK5
    BrownK5 Registered Member
    Jan 8, 2006
    25
    gresham,OR
    I am going to shackle flip my blazer. i was planning on just cutting a hole in the bottom of the stock perch. would it be strong enough if I did just that? I was thinking of reinforcing it with some steel, welding it from the bottom up to the top of it at kind of a 45 degree angle. I just cant see going out and dropping $185 on an ORD shackle flip. any pics of what people have done? would be nice- thanks alot.
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I bought a Sky shackle flip when they were on sale for about $100.
    Regarding cutting out the stock hanger, a lot of people have done that. The problem is you really need to reinforce the bracket since you are removing a large portion of the metal that holds everything together, especially if you want to have enough room for the shackle to move around. The other issue that the shackle will not be at a good angle...all of the aftermarket brackets move the frame to shackle mounting location forward to correct the angle.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Werd!
  4. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    I am also intrested in this .. does any one have any pics?????
  5. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    This is what I plan on doing, but I am going to be using 56" springs. So I shouldnt have a problem with shackle angle.
  6. BrownK5
    Jan 8, 2006
    25
    gresham,OR
    are sky flips different from ORD? Im almost thinkin if im gonna do it, do it right. where can i find sky products?
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
  8. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    If you want to do it right, come off the money and go with ORD. Couldn't be happier with my flip...
  9. NYDIESELDAVE
    NYDIESELDAVE 1/2 ton status
    Aug 6, 2005
    166
    Penfield, NY
  10. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Rollin Good for over a year.
