another shackle flip question
Discussion in 'The Garage' started by poolcues, Oct 4, 2006.
  1. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    i just got through doing a suspension swap on 2 swb k10's. old k10 had 6" springs in the front, 1" tc drop, 2" add a leafs and 4" locks in the rear. other k10 has those same front springs, 1" tc drop, 2" add a leafs and a 4" shackle flip. my question is how many degrees will the shackle flip itself rotate the axle. need new shims in the rear and don't want to buy more pairs than i need to trouble shoot my driveline vibration. i even swapped axles. did a search and didn't find the exact answer i needed.thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the shackle flip rotates the pinion up just the right amount that i did no have to use any shims or any thing
  3. poolcues
    Dec 13, 2004
    232
    Charlotte,NC
    hmmmm...... i wonder if i should drop the tc 1/4" more
