Another shock question, and a poll to boot...
Discussion in 'The Garage' started by Desert Rat, Jun 3, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Got the D60 and Corp14ff installed. Went with 6 inch TC springs up front and the ORD shackle reversal in back with 2 inch TC springs. It's shock time. Did a search but want opinions. I want an adjustable shock so I can change the rate for on and off road handling since the swaybar dissappeared with the crossover steering install. So, which shocks to get and part numbers if anybody has them?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Rancho 5012's up front for me, didnt need an adjustable shock since Im rarely on road with it. With Ford towers and 4" springs it was the longest shock I could fit without the tower hitting the cab. /forums/images/graemlins/thumb.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Bilstein 5100's /forums/images/graemlins/thumb.gif
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    DT 8304's
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] ding, good man, can't forget the naked option... some people have been forgetting around here.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/confused.gif
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Go with the Bilstien 5100, yes they cost a bit more but you will be happiest with em.
    I personally run SAW race runners that are 2.5" piston diameter with external resivior's and 14" of travel.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Procomps or Bilsteins. Monotubes all the way......
    Unless you're cheap like me. Then you settle for $15 gas charged Gabrials.
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I have read all the posts on Bilsteins, but they don't make an adjustable one. Since I am ditching the swaybar, I want to be able to adjust the shocks to compensate when I'm in the twisties on the slab over the Sierras into Nevada. Then soften them up on the trail. This limits my choices quite a bit, but I'm set on adjustables.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Monotube shocks are far more agressive than any half ass adjustable twin tube design. There is a reason they're not adjustable....the adjustment is built in at the factory where they install that high pressure gas cylinder.
    Rancho = Hype. I'm so glad I learned this before I ever wasted big $$ on a set. I had a set of RS 5000s and I wasn't impressed, they didn't do anything that a $10 shock wouldn't do.
    Rancho also = Monroe. If you want Monroe shocks you can go to an auto parts store. You don't need to order them from a high performance place just to get the same shock painted white with a red boot in the box.
  11. zcarczar
    Feb 10, 2002
    2,495
    With a good high pressure mono-tube like the Bilstiens you dont need to re-adjust them for different terrain. Because of their superior design they work better overall than the shitty triple tube Rancho adjustable ones. I dont need to adjust my monotube shocks for different terrain because they work well in everything, from high speed street driving to rock crawling they just work awesome.
  12. camoman
    camoman Newbie
    Jun 3, 2004
    4
    I run rs9000's all round next to black diamond blades.
    Just awesome.
    Even better than my hilux with full procomp comfort wise.
    Flex is phenomenal
  13. chevy_addict
    chevy_addict 1/2 ton status
    May 4, 2004
    138
    You are here, I am not
    Hey Tim, I'm cheap, do you have model and/or part numbers?
    Dave
  14. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    The reason I wanted adjustable was to stiffen them up for asphalt driving to keep the sway down to a minimum. I know the Bilsteins are better overall, but I want to compensate for the lack of a swaybar. But, I've seen comments ranging from all over the board as to whether or not taking the swaybar off is a problem for asphalt driving. Some say they didn't notice a difference, others say they wish they still had it on.
  15. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Bilsteins
  16. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    My blazer is my daily driver and I dont have my swaybar hooked up. I am running the rancho 9000s and I am not impressed. I have tried all the settings and all it does is change the way it handles bumps and I corner it pretty hard(no difference). My next step is to go with the bilstein 5150. Adjustable shocks are a joke, spend the money and get good monotube shocks especial if you drive on the street alot. /forums/images/graemlins/thumb.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not all adjustable shocks are a joke, just Ranchos.
    I'm going to buy some Bilstein 5150s in 14" travel as soon as I get the money/time to make rear mounts for a set.
    If you're cheap, get the Gabrials I have now. They're $15 each, G63438 is the part number, they're gas charged twin tubes just like a set of RS 5000s. They're about 30" long extended and about 18" compressed with 12.53" of travel.
    Mine work fine for now but I'm going to go to a much softer spring I think in my next stage.
    Like I said above and others have agreed with me, adjustable = crap. There is no question that Monotubes are FAR superior for damn near every application.
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Patch, my 84 Live Axle yoter, corners far better with the 5100's and no sway bar than it ever did with the RS5000's and a sway bar. To offer some background, I used to work as a crew/prep person on several different road racing cars. Patch will never be a competitive road racer (not even close), but I do know what I'm talking about here.
    I've been told that the 5k valving is the same as the 9k valving when set on '5' if you have the single damper per tire p/n. If you run a single multi-damper per tire valved RS9k the valving will be softer and will sway more even when set on 5
    You'll like the ride quality, the on-road, and the off-road manners of the 5100's far better than the 9k's on any setting. And it's one less thing to have to screw with.
  19. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    You guys are starting to sway me towards the Bilsteins..........Hmmmmmmmmmm /forums/images/graemlins/thinking.gif
  20. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    *sway* you? mwuhahahahahaha...
    -- A
