Another Steering Box Question
Discussion in 'The Garage' started by K5MONSTERCHEV, Feb 25, 2004.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    My buddy has an 87 chevy 2wd, and I have a 72 4wd. Were going to swap boxes.
    I heard somewhere here of a conversion fitting so I can run my SAE lines and the Metric fitting box, and so he can run his Metric lines and my SAE fitting box.
    OR my other idea (which id rather do) is, would it just be easier to switch the sector shafts?? If so, how har is this? Thanks in advance. /forums/images/graemlins/thumb.gif
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I just replaced my sector shaft with one out of a 2wd and it was pretty easy. If your just going to replace the shaft it's just a matter of taking out the 4 bolts on the cap and pulling the shaft out. But in my opinion, if your going to have the box out and opened already, just go ahead and do a complete rebuild on it. I actually had a friend do this since he had done it many times before. But it didn't seem all that hard. The kit usually comes with a good diagram showing where everything goes.
    Good Luck /forums/images/graemlins/peace.gif
  3. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    MAN, that seems too easy. Thats probablly what Ill do. The sector shafts will interchange no prob? Ill look into a rebuild kit tomorrow.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So if I am understanding this , you are going crossover with side to side box, and he is going solid axle conversion with no crossover with your front to back box. Or are you just getting his box? Sounds to me like both rigs will be tons better /forums/images/graemlins/k5.gif /forums/images/graemlins/waytogo.gif
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Correct, Im doing crossover, he has a 2wd were converting to 4wd and hes going to use stock steering, for now.
  6. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Anyone else?
  7. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Just sawp out the boxes. You need a 2wd box for the crossover and He needs a 4wd box for 4x4.
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    My main question was about the fittings. His is metric, im SAE.
  9. unick
    Aug 16, 2003
    4,286
    get some adapters. If you dont want to change them just swap the shaft. That would be the easiest thing to do.
    Nick
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah I guess ill just swap shafts since you guys say it will work!
  11. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thanks!!! /forums/images/graemlins/thumb.gif
    So I just pull out the 4x shaft and put in the 2x one, correct?
  13. limey
    Dec 17, 2002
    121
    midland texal
    yep it slides right in
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thank you! /forums/images/graemlins/thumb.gif
