another steering hole taper question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Oct 17, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    OKay I just ordered the Snap on tapered reamer, Part #R121
    1/2"-1" Taper. This should be about a 7 degree overall taper. I thought that all of the steering componets used on the chevy's had the same taper. After reading the Cross over section on off-road design it say the drag link ends and the tie-road ends are different!? Did I just waist $60? I tried fiting a tie rod end into my old steering arm and it seem to fit fine. Anyone have any info?
    Thanks,
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Stephen?
    Still Poundin' "pavment" after all these years!!! [​IMG]
  3. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    There are different tapers, but from what I've seen, most all (domestic) tie rod ends use the 1-in-8 taper rate. You're okay with the Chevy stuff, at least. The drag links are different - different size - same taper. Just have to change how deep you use the taper.
    --Rob
  4. mpascino
    Jan 1, 2001
    557
    Connecticut
    Thanks a lot, I don't feel so bad anymore!
    Mike
  5. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    You are fine. The only difference on the rod ends is the left and right hand threads. The 7degree reamer is a very common taper. I just had my Machinist build a steering block for my crossover, he bought the same reamer.
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hey Mudzer,
    Is that 7 deg. taper just one side, so it would be a 14 deg included taper or is it a 7 deg. included which would be 3.5 deg. per side? I think it is probably a 14 included angle but I just wanted to know for sure. Do you think you could ask your machinist for me? Thanks.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  7. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Wow $60 for a SnapOn Remer! I bought mine rather recently for $37. If this was through your dealer check <a target="_blank" href=http://snapon.com>snapon.com</a>for better pricing
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
