Another stupid 10-bolt carrier question...
Discussion in 'The Garage' started by NerdBoy, Aug 23, 2005.
  1. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Simple question, but I can't find a simple answer...
    Will the carrier out of a rear 10-bolt fit in a front 10-bolt axle?
    When GM upgraded the spline count in the 10-bolt rear ends in 88 or 89 or so, did they also upgrade the spline count in the front?
    Thanks!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes and yes . Although some carryover could of happened at first . You almost always find 30 splines front and rear from 89 on .
    You may also change a 30 spline to 28 spline by using the 28 spline carrier . I am doing my "new: 89 Sub front axle so I can use all the spare shafts I have . ( and give the 30 spline stuff to a guru ) .
  3. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    got some 30spline shafts if you're interested
