Another Stupid 14 Bolt FF Question
Discussion in 'The Garage' started by BrianDamage, Sep 20, 2005.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    Yeah, yeah I know......kill me.....but I think I'm being misinformed and don't know enough to know for sure.
    I was telling a friend about my plans with my K5..kind of a long-term, build as I an afford type thing. My stock rear axle is about shot, and goes through U-Joints like crazy. I don't have the time, know-how or tools to rebuild it, and would really rather just put a 14-bolt ff in there instead.
    My plan was to buy a rebuilt 14 bff, with new gear ratio and disk brake kit already installed. What I was going to do was buy some CHEAP 8-lug 15 inch rims, so that I can run the 33 inch tires that I have on it now. I was just going to unhook my front drive shaft until I could afford a new front axle (hopefully dana60).....all that means is I won't be able to drive around my hunting lease, I'll have to stay on the main road and either take a 4-wheeler or ride with someone else.no big deal.
    Anyway, this guy was telling me that 15 inch rims wouldn't fit on all 14 bff axles? He says there are 2 differant kinds.I think he said one came off of a 3/4 ton, the other off of a 1 ton, and the brake drums are differant sizes, so the 15 inch won't fit on the 1 ton.
    Is he smoking crack?
    After getting the new front axle and lift kit, I plan on moving up to a 16.5 " rim and 38's.... but the 33's I have are pretty new and I want to get the most wear I can out of them first.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    from my understanding... 15" rim will fit a 14bolt ff... and if you do disc that makes a bit more room...
    drums are 13" i think and rotors are 11 or 12".....
  3. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    why would you need to disconnect the front axle ?
    if the gear ratio is the same as the 14bff you get , you can run the front axle
    especially with 33's.
    and yes you can run 15" rims on the 14bff.
  4. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    A 15 inch rim with 4.25 backspace will fit on either 14bff (I had one with the big brakes) However rootbreaker is a bit off with the disk brakes making more room. When I did my disc brake upgrade I had to grind the calipers quite a bit to get the 15's to fit. Sure the rotors are alot smaller than the drums but the calipers stick out beyond that.
  5. BrianDamage
    May 14, 2001
    753
    Alabama
    When I buy the 14 bolt, I'm going to have a differant gear ratio in it..that way I won't have to change it again when I put the 38's on it. It's just got the stock 3.42 (or is 3.43? :doah: ) gears now.
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    aight stand corrected... have only owned 16.5's :bow:
    d44 calipers are smaller than the d60's so I was guessing that they would fit :doah:
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need a bigger than 15" rim for disc brakes.
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I have disks on my 14BFF and 15X10's with 4.25" BS fit just fine. I did have to clean up some of the casting flash on one of the calipers, but otherwise it was pretty straightforward. :D
    You should have no problems with 15" rims on a disked 14BFF. ;)
  9. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    There are a lot variables like aluminum vs. steel too... (steel wheels being thinner for the same strength). I suspect that many of the things done in the CK5 article about running 15's on a D60 also apply to running them on a disc'd 14b... check there for how to clearance grind the calipers.
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    There are no 15" 8 lug aluminum wheels that i've ever seen. 15's on a 14 bolt is NBD, and as already mentioned at most you'll have to spend about 10 seconds grinding the rear calipers to suit...
    Ironically I have run into fitment problems with a SF 14 bolt...the fins on the drum (which is a lot more outboard) had to be ground to fit the 15's on my buddies truck.
    Rene
  11. BrianDamage
    May 14, 2001
    753
    Alabama
    Good deal. :waytogo:
