Another TBI question
Discussion in 'The Injection Section' started by HammaK5, Jan 5, 2007.
  1. HammaK5
    HammaK5 Registered Member
    May 20, 2005
    44
    hephzibah ga
    Ok here goes 87 R30 454N TBI. Engine just rebuilt when I drive it now from no throttle up to 1/4 throttle engine stumbles almost like a lean condition and a cold engine. I checked the connections and grounds any help would be greatly appreciated.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You could try resetting base idle which would set the IAC also. Do you have winaldl? Check for vacuum leaks, check your timing is correct (usually0* on tbi but I'm not sure about 454s), make sure your manifold is tightened down (they tend to back off a bit). Are you sure you set your valve lash correctly? lots to check!!
