Another TBI retrofit question
Discussion in 'The Garage' started by Mr.Chevy4x4, Feb 6, 2003.
  1. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Who has done it and what wiring harness did you use? I am interested in keeping the factory harness. What modifications will be necessary? Is there a company the will modify the harness for ease of installation?
    Thanks in advance!
    Mike
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    painless sells a kit. part numbers 60101 is standard length, and kit 60201 is 4 feet extra length.
    i am going to get it. i have almost everything else i need for the TBI swap. a new carb is about 279 dollars. the harness is 279 dollars from Sumit.
    grant
  3. 4DiggerDan
    4DiggerDan 1/2 ton status
    Feb 2, 2003
    103
    Montucky, USA
    Speartech might... I know they got a lot of goodies for putting in a TPI.
  4. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I kept mine all gm...scrounged all the fuel lines etc. from a donor 87 up K5...harness and 2 pulse vss from Howell...been driven for two plus years now...4.10's and 35's...11.3 mpg. Getting ready to have a custom chip burned currently. Need to correct for altitude and a few other items...
    Doug W.
  5. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    Starting my TBI swap next week. Got what I needed off an 88 Blazer, the tbi unit, computer, distributor, sensors and all. and got the harness,pump,chip etc. from Howell. Howell will modify a factory harness but its $$$$ /forums/images/graemlins/tongue.gif
    Clay /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
    84 K10 D44,14B Detroit,8" Superlift,4.10's,355 TBI,700R4,208
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Use the factory harness as long as its not all hacked up. You only have to make a few power connections and ground it. I used the factory harness for my TPI conversion, it was actually very easy
  7. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    Mike this fella can make you a custom harness http://www.customefis.com/
    i know it's not what yer looking for but it mught help.
    besides you don't need a stinking TBI you should sell it to me /forums/images/graemlins/grin.gif
  8. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    No, I have a TPI I need to sell to you! I have once again changed my mind. I am going to go TBI since I have everything, and sell the TPI setup. I have a fresh set of 305 TPI heads that have had larger valves installed that you can buy when you get the rest of it from me! /forums/images/graemlins/grin.gif
    Mike
  9. beater74
    May 29, 2001
    1,749
    atlanta
    you've got mail /forums/images/graemlins/grin.gif
