Another tire fit question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Jun 17, 2001.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I blew another tire tonight. That's 3 out of 4 now. So I need some new tires. I was waitting for a lift but I don't think I can wait any longer. OK, here's my question; Can I run 33x12.50 BFG AT tires with out a lift on an '88 if I stick to roads?
    (Insert gif here)
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    If your sway bar is connected and you're not wheeling it you should be good. The closer to stock offset the better, a wider rim will be more likely to cause hitting probs.
    Rene
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    well, i dont have a definite answer but you should just take some measurements of the wheel well and see how you think they fit. Im running 36's with lift bit they are barely larger than the sides of the well. i would think the 33's would fit no problem.
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  4. SuperUnknown
    Feb 8, 2001
    165
    ... I have 15" X 10" rims, I think there stock ...
    (Insert gif here)
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    If they're stock they're either 15x7's or 8's...and shouldn't be a problem. Mudhog runs 33x12.5 with no lift and when we wheeled in Oregon POWERMAD also showed up with 33x12.5 and no lift. POWERMAD actually wheeled his pretty hard and did have some fender boo-boos, but Mudhog didn't have any probs. Mudhog has more backspacing though.
    Just chuck em on and don't wheel it.
    Rene
  6. SuperUnknown
    Feb 8, 2001
    165
    Thanks man.
    Fast friendly service 24 hous a day!
    (Insert gif here)
  7. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    there are also a few tires on the market that are 10.5" wide or 9.5" wide...
    don't know if these would fit better in the scenario, but might be something to think about...
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i am running 33'' on my stock 74. matter of fact you could call it lowered. the springs in the rear are flat and the front are reverse curved. i just trimmed the front a bit. most people end up doing that anyway. its an option
    BFG makes 33-10.5-15r they are nice. i almost put them on the fron. but then i said F^ck it. and cut the fenders.
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    my 77 blazer has no lift (putting a lift on next week) and i run 33x12.5x16in tires and i have never had mine rub rene has seen mine in action i do wheel fairly hard and have jumped mine and i have no rubbing the key with mine is i have a positave offset rim= no rubbing
    a negative offset with no lift= rubbing i hope this helps some
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    33s have always fit stock as far as I've seen. A number of my friends have run them with absolutely no rubbing.
    I would never run 9.50 or 10.50 tires. They're just not wide enough. You've got to have more tire on the ground than that to get good traction.
    Tim
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    IF you stick to roads and mild trails you will be fine. Just be careful if you start getting twisty and sharp turns!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  12. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    3 out of 4 went flat, sounds like you're running Generals!! LOL
    The BFG's should treat ya right.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  13. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I've never had a flat with my Generals...of course I only have 40,000 mles on em so its still possible.
    Rene
  14. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You sure those aren't Firestones....? [​IMG]
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
