Another trans/t-case ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Oct 28, 2001.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Ive gotta go to the 205 case fast, but what trans? Ive currently got a th350 but I have a th400 at the shop. Do I go to the 400 or stay with the 350? The best i can figure im gonna have to change the trans output either way. (The 205 is off a 350) How much does a new output for the trans and a new input for the t-case cost? Any info is appreciated.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, the outout shaft itself is not too expensive...Its the labor if you pay someone to install it that gets you, as you have dis-assemble the ENTIRE tranny to replace the output shaft.
    As far as swapping the input on the T-case....This would be much cheaper if you do it your self. The t-case is real easy to dis-assemble and put back together if you have a mechanical mind and some tools. But you shouldn't need to do both I dont think.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Refresh our memory as to your rig's Engine, tire size and gearing.
    Still Poundin' "pavment" after all these years!!! [​IMG]
  4. outlaw612
    Feb 11, 2001
    2,342
    The truck has a 350 with 36x12.50 Tsl's and 3.73 gears. Im hoping to go to 4.10's.
