Another Ubolt ? with an 8' spring lift
Discussion in 'The Garage' started by 73K5Kid, Oct 16, 2006.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I am running an 8' spring lift on 1/2 ton 10 bolts. What lenght of ubolt will I need for the 14 bolt? Will the new ubolts that are installed on it now work with the 14bolt? The ubolts are new and I assume came with the lift thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    New U-bolts will be required when swapping in the 14ff. Length depends on how thick your leaf pack is and also if you have any degree shims installed or are running a zero rate.
  3. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    Thanks again 4x4high
  4. goldwing2000
    goldwing2000 Guest
    Wow... you're running an 8 foot lift?? :eek1:
  5. 73K5Kid
    Sep 24, 2002
    583
    chandler az
    8 inch :rolleyes: :haha:
