another valve cover gasket question.
Discussion in '1982-Present GM Diesel' started by colbystephens, Mar 5, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so my valve covers aren't perfectly flat and i used the gaskets from my felpro top end kit which happen to be cork. i'm still in the assembly stage of my engine (last steps) and so what i did was poured some oil over the cylinder heads before i put the valve covers on, then when i put the gasket/cover on, i tipped the engine to the side a bit to make doing the other side slightly more convenient - oil leaked out. so i'm wondering if this will be a problem when it's in the engine straight up and down. should i take it off and use one of the rtv sealers? what type should i use?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    How tight did you go on the bolts?
    With the cork gasket you don't want to go too tight it will tweak the cover and leak.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    the cover was originally "tweaked", but i'm sure that i went overboard - i don't have a torque wrench which goes to a low enough torque. :(
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    not sure how the 6.2 covers are setup for bolts, but i'll bet bottom dollar its because its tweaked... take it off, lay it on a flat surface and see how wobbley it is..
    you should be able to get it back in shape with some muscle or a hammer and piece of thick flatstock...
  5. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Just get a new cover they arent exactly rare.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I straighten mine on a flat steel surface.
    And I just use my 1/4" drive ratchet 4" long handle and just one handed snug tighten.
    I do the same on my auto trans pan gasket when I use the cork gasket, never had a problem after that.
    But make sure you start with a straight edge cover.
  7. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I use RTV only (no other gasket) with good results. But I straighten the mating surfaces.
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    spoke with my machinist, and he recommended that I use 3m window sealer to hold the gasket in place, and wait for it to set. then use a small amount of rtv sealer on top of the cork gasket. i'm going to go with this method tonite.
  9. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    he prolly meant 3M weatherstrip adhesive.... very common to use that...
    i prefer Hi-tack myself...
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    cool. thanks for the tip. that's what the parts store recommended too.
  11. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I use the neoprene gaskets and have no leaks. I hate cork gaskets..:crazy:
    Rene
